Salta al contenuto principale
Alcatel One Touch Fierce Front Facing Camera Replacement
Cosa ti serve
  1. Alcatel One Touch Fierce Front Facing Camera Replacement, Rear Case: passo 1, immagine 1 di 2 Alcatel One Touch Fierce Front Facing Camera Replacement, Rear Case: passo 1, immagine 2 di 2
    • Pry with a plastic opening tool, or your fingernail, in the divot at the bottom left corner of the phone.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  2. Alcatel One Touch Fierce Front Facing Camera Replacement, Midframe: passo 2, immagine 1 di 3 Alcatel One Touch Fierce Front Facing Camera Replacement, Midframe: passo 2, immagine 2 di 3 Alcatel One Touch Fierce Front Facing Camera Replacement, Midframe: passo 2, immagine 3 di 3
    • Remove the 11 Phillips #000 screws.
    • The midframe should lift free.
  3. Alcatel One Touch Fierce Front Facing Camera Replacement, Battery: passo 3, immagine 1 di 2 Alcatel One Touch Fierce Front Facing Camera Replacement, Battery: passo 3, immagine 2 di 2
    • Use the tip of a spudger to pull back the yellow tape covering the battery connector.
    • Use a pair of tweezers to pull the battery connector from its port.
    • Be careful not to tear the battery from its connection.
  4. Alcatel One Touch Fierce Front Facing Camera Replacement, Camera: passo 4, immagine 1 di 1
    • Carefully remove the motherboard from the rest of the phone.
  5. Alcatel One Touch Fierce Front Facing Camera Replacement: passo 5, immagine 1 di 2 Alcatel One Touch Fierce Front Facing Camera Replacement: passo 5, immagine 2 di 2
    • Use a pair of tweezers to disconnect and remove the front facing camera from the motherboard.
Conclusione
Altre 5 persone hanno completato questa guida.
2 Commenti
tenx tenx tenx !!?
ismail - Replica
I paid for a phone to capture precious moments, & the pictures are horrible, how can this be fixed??? This is wrong on all levels, I feel that we should be able to try any phone out before purchasing, so we know what we are buying, I'm returning my phone & wouldn't recommend this brand to anyone.
Jeanne Edenfield - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 6,502
