Salta al contenuto principale
Alcatel IdealXCITE Battery Replacement
Cosa ti serve
  1. Alcatel IdealXCITE Battery Replacement, Battery: passo 1, immagine 1 di 3 Alcatel IdealXCITE Battery Replacement, Battery: passo 1, immagine 2 di 3 Alcatel IdealXCITE Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Place your finger in the small notch on the left corner of the phone.
    • Use your finger to gently pull up on the back cover where the notch is located.
    • Gently pull up on the back cover, working around the phone.
    • Remove the cover from the phone, and set it aside for later installation.
  2. Alcatel IdealXCITE Battery Replacement: passo 2, immagine 1 di 3 Alcatel IdealXCITE Battery Replacement: passo 2, immagine 2 di 3 Alcatel IdealXCITE Battery Replacement: passo 2, immagine 3 di 3
    • Place your thumb in the small notch between the battery and the phone.
    • Use your thumb to gently pry the battery up at the notch, releasing it from the phone.
    • Take note of the contacts in the phone and on the battery for reinstallation.
Conclusione
In order to reassemble your device, follow the instructions in reverse order.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 13
Tutti i Tempi: 447
