Salta al contenuto principale
Akai Retro Boom CD player model CE2200 Speaker Replacement
Cosa ti serve
  1. Akai Retro Boom CD player model CE2200 Speaker Replacement, Speaker: passo 1, immagine 1 di 3 Akai Retro Boom CD player model CE2200 Speaker Replacement, Speaker: passo 1, immagine 2 di 3 Akai Retro Boom CD player model CE2200 Speaker Replacement, Speaker: passo 1, immagine 3 di 3
    • Remove the batteries located under the radio by sliding open the removable panel.
  2. Akai Retro Boom CD player model CE2200 Speaker Replacement: passo 2, immagine 1 di 3 Akai Retro Boom CD player model CE2200 Speaker Replacement: passo 2, immagine 2 di 3 Akai Retro Boom CD player model CE2200 Speaker Replacement: passo 2, immagine 3 di 3
    • Use a six inch Phillips #2 screwdriver to remove the screws that hold the clamshell body together.
    • There will be six (6) screws at the bottom of the speaker, one (1) screw in the CD player, and two (2) under the battery panel. A total of nine (9) screws.
    • Each screw is 12.7 millimeters.
  3. Akai Retro Boom CD player model CE2200 Speaker Replacement: passo 3, immagine 1 di 3 Akai Retro Boom CD player model CE2200 Speaker Replacement: passo 3, immagine 2 di 3 Akai Retro Boom CD player model CE2200 Speaker Replacement: passo 3, immagine 3 di 3
    • Use the plastic spudger or the Jimmy to gently pry open the plastic shell halves from each other.
    • The red boxes highlight the speakers you are replacing.
    • Be careful of loose wiring when prying the halves open.
  4. Akai Retro Boom CD player model CE2200 Speaker Replacement: passo 4, immagine 1 di 2 Akai Retro Boom CD player model CE2200 Speaker Replacement: passo 4, immagine 2 di 2
    • Unplug the small red connector from the circuit board.
    • Be firm with your pinch and pull gently.
  5. Akai Retro Boom CD player model CE2200 Speaker Replacement: passo 5, immagine 1 di 2 Akai Retro Boom CD player model CE2200 Speaker Replacement: passo 5, immagine 2 di 2
    • Carefully remove the speakers from their placeholders by lifting each speaker up.
    • Set removed speakers aside and recycle them later.
  6. Akai Retro Boom CD player model CE2200 Speaker Replacement: passo 6, immagine 1 di 2 Akai Retro Boom CD player model CE2200 Speaker Replacement: passo 6, immagine 2 di 2
    • Insert new speakers where the old ones were located
    • Then connect the new speakers to the circuit board.
Linea Traguardo
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 272
