Salta al contenuto principale
Introduzione
Use this guide to replace the volume knob and pitch bender if either of the knobs break, stop working, or get stuck and won't move.
Parti
Nessuna parte specificata.
  1. Remove all the selector knob covers by pulling them off.
    • Remove all the selector knob covers by pulling them off.
  2. Using needle nose pliers, remove the washers from the four corner selector knobs.
    • Using needle nose pliers, remove the washers from the four corner selector knobs.
  3. Flip the device over. Using a Philips #2 screw driver, remove the fourteen 10.3 mm black screws holding the back panel in place.
    • Flip the device over. Using a Philips #2 screw driver, remove the fourteen 10.3 mm black screws holding the back panel in place.
  4. Carefully flip the device to the front making sure you secure the face plate and the chassis together. Please use care in following the step above to avoid ripping the ribbon cables connecting the two sides. Please use care in following the step above to avoid ripping the ribbon cables connecting the two sides.
    • Carefully flip the device to the front making sure you secure the face plate and the chassis together.
    • Please use care in following the step above to avoid ripping the ribbon cables connecting the two sides.
  5. Rotate the device 180 degrees and carefully remove the face plate by slightly lifting the screen side towards you and then sliding the bottom out from under the keys. Use care when doing the step above so that the ribbon connectors which connect the top of the chassis to the top of the face plate are not damaged. Use care when doing the step above so that the ribbon connectors which connect the top of the chassis to the top of the face plate are not damaged.
    • Rotate the device 180 degrees and carefully remove the face plate by slightly lifting the screen side towards you and then sliding the bottom out from under the keys.
    • Use care when doing the step above so that the ribbon connectors which connect the top of the chassis to the top of the face plate are not damaged.
  6. Rotate the device 180 degrees, so that the motherboard is closest to you.
    • Rotate the device 180 degrees, so that the motherboard is closest to you.
    • Take caution to not damage the ribbon cable connecting the face plate to the chassis.
    • Remove the ribbon cable connecting the knobs to the mother board by gently wiggling and pulling it away from the motherboard.
  7. Using a Phillips #2 screwdriver, remove the four 9.5 mm silver screws holding the knobs to the face plate. Using a Phillips #2 screwdriver, remove the four 9.5 mm silver screws holding the knobs to the face plate.
    • Using a Phillips #2 screwdriver, remove the four 9.5 mm silver screws holding the knobs to the face plate.
Conclusione
Altre 4 persone hanno completato questa guida.
Serbinder Singh
Membro da: 30/01/2013
72 Reputazione
3 Guide realizzate
Cal Poly, Team 20-6, Maness Winter 2013 Membro di Cal Poly, Team 20-6, Maness Winter 2013
CPSU-MANESS-W13S20G6
5 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 11
Tutti i Tempi: 2,156
