Salta al contenuto principale
Akai MPK25 Keys Replacement
Cosa ti serve
  1. Akai MPK25 Keys Replacement, Face Plate: passo 1, immagine 1 di 1
    • Remove all the selector knob covers by pulling them off.
  2. Akai MPK25 Keys Replacement: passo 2, immagine 1 di 1
    • Using needle nose pliers, remove the washers from the four corner selector knobs.
  3. Akai MPK25 Keys Replacement: passo 3, immagine 1 di 1
    • Flip the device over. Using a Philips #2 screw driver, remove the fourteen 10.3 mm black screws holding the back panel in place.
  4. Akai MPK25 Keys Replacement: passo 4, immagine 1 di 3 Akai MPK25 Keys Replacement: passo 4, immagine 2 di 3 Akai MPK25 Keys Replacement: passo 4, immagine 3 di 3
    • Carefully flip the device to the front making sure you secure the face plate and the chassis together.
    • Please use care in following the step above to avoid ripping the ribbon cables connecting the two sides.
  5. Akai MPK25 Keys Replacement: passo 5, immagine 1 di 3 Akai MPK25 Keys Replacement: passo 5, immagine 2 di 3 Akai MPK25 Keys Replacement: passo 5, immagine 3 di 3
    • Rotate the device 180 degrees and carefully remove the face plate by slightly lifting the screen side towards you and then sliding the bottom out from under the keys.
    • Use care when doing the step above so that the ribbon connectors which connect the top of the chassis to the top of the face plate are not damaged.
  6. Akai MPK25 Keys Replacement, Keys: passo 6, immagine 1 di 2 Akai MPK25 Keys Replacement, Keys: passo 6, immagine 2 di 2
    • Using needle nose pliers, grip the top of the spring coil, that is holding down the key, and gently lift the spring away from the key.
  7. Akai MPK25 Keys Replacement: passo 7, immagine 1 di 1
    • Lift the key from the front of the keyboard towards the back in order to remove it completely.
Conclusione
To reassemble the keyboard and close up the case, follow these instructions in reverse order.
Altre 7 persone hanno completato questa guida.
Will Saba
Membro da: 01/11/13
412 Reputazione
2 Guide realizzate
Cal Poly, Team 20-6, Maness Winter 2013 Membro di Cal Poly, Team 20-6, Maness Winter 2013
CPSU-MANESS-W13S20G6
5 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 29
Tutti i Tempi: 11,348
