Salta al contenuto principale
Akai MPK25 Face Plate Replacement
Cosa ti serve
  1. Akai MPK25 Face Plate Replacement, Face Plate: passo 1, immagine 1 di 1
    • Remove all the selector knob covers by pulling them off.
  2. Akai MPK25 Face Plate Replacement: passo 2, immagine 1 di 1
    • Using needle nose pliers, remove the washers from the four corner selector knobs.
  3. Akai MPK25 Face Plate Replacement: passo 3, immagine 1 di 1
    • Flip the device over. Using a Philips #2 screw driver, remove the fourteen 10.3 mm black screws holding the back panel in place.
  4. Akai MPK25 Face Plate Replacement: passo 4, immagine 1 di 3 Akai MPK25 Face Plate Replacement: passo 4, immagine 2 di 3 Akai MPK25 Face Plate Replacement: passo 4, immagine 3 di 3
    • Carefully flip the device to the front making sure you secure the face plate and the chassis together.
    • Please use care in following the step above to avoid ripping the ribbon cables connecting the two sides.
  5. Akai MPK25 Face Plate Replacement: passo 5, immagine 1 di 3 Akai MPK25 Face Plate Replacement: passo 5, immagine 2 di 3 Akai MPK25 Face Plate Replacement: passo 5, immagine 3 di 3
    • Rotate the device 180 degrees and carefully remove the face plate by slightly lifting the screen side towards you and then sliding the bottom out from under the keys.
    • Use care when doing the step above so that the ribbon connectors which connect the top of the chassis to the top of the face plate are not damaged.
Conclusione
Cal Poly, Team 20-6, Maness Winter 2013 Membro di Cal Poly, Team 20-6, Maness Winter 2013
CPSU-MANESS-W13S20G6
5 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,683
