Salta al contenuto principale
Airox Legendair Battery Replacement
Attrezzature medicali
Né iFixit né questa guida di riparazione sono approvati dal produttore del dispositivo medicale o affiliati ad esso.
Cosa ti serve
  1. Airox Legendair Battery Replacement, How to Properly Clean the Airox Legendair: passo 1, immagine 1 di 1
    • First, switch off the device.
    • Place the device in a clean and open environment.
  2. Airox Legendair Battery Replacement: passo 3, immagine 1 di 1
    • Using a cloth or a sponge slightly dampened with a bactericide or germicide solution, gently clean the outside of the device.
  3. Airox Legendair Battery Replacement: passo 4, immagine 1 di 1
    • If necessary, spray the device lightly with the germicide solution, taking account of the requirements discussed in the preliminary operations.
    • Do not allow any liquid to enter inside the device (in particular through the cooling apertures).
    • Use a gentle air blast to clear away any remaining liquid from ventilator.
  4. Airox Legendair Battery Replacement, Battery: passo 6, immagine 1 di 1
    • Make sure to turn off the ventilator before starting the repair.
    • Before you start the battery replacement process, make sure that the device has been placed in a clean and open environment.
  5. Airox Legendair Battery Replacement: passo 7, immagine 1 di 1
    • Remove each attachment screw from the battery cover.
  6. Airox Legendair Battery Replacement: passo 8, immagine 1 di 1
    • Remove the battery cover carefully by holding the rails and pulling toward the rear of the device.
  7. Airox Legendair Battery Replacement: passo 9, immagine 1 di 1
    • Extract the current battery and replace it with the new battery.
  8. Airox Legendair Battery Replacement: passo 10, immagine 1 di 1
    • Confirm that all elements line up together. Then, reattach the battery cover with the attachment screws that were removed in Step 2.
  9. Airox Legendair Battery Replacement: passo 11, immagine 1 di 1
    • Switch the device to "Set Up Mode" by pressing the On/Off switch.
    • Hold the menu key until the menu options appear on the screen.
    • Select the "MAINTENANCE" option with cursor.
    • Select "Voltage control" and verify that the voltage of the battery is 28.5±1V.
Conclusione
Perform the final inspection procedures by confirming that every screw is secure before putting back into service.
Caleb Erlenborn
Membro da: 04/09/20
174 Reputazione
1 Guida realizzata
Cal Poly, Team S7-G15, Paton Spring 2020 Membro di Cal Poly, Team S7-G15, Paton Spring 2020
CPSU-PATON-S20S7G15
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 377
