Introduzione
Since the original AirPods came out all the way back in late 2016, many of their batteries have died out and can't hold the same amount of charge as they did 7 years ago. This guide aims to solve that issue, but repairing AirPods batteries is very challenging. To take you through the grueling process, many contributors at iFixit compiled this guide to help you complete the repair. Let us begin!
Cosa ti serve
Panoramica Video
This is the first part of the process of replacing the battery with the damaged airpods, mainly to see the internal structural details close-up, to prepare for the complete disassembly below.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Use a pair of tweezers to shake the antenna on the outside of the battery to the left and right, then drop the debonding agent, and finally insert a thin plastic piece into the middle of the battery and the inside of the antenna, up and down, to loosen the battery and the antenna.
Install and test charging, played some music, checked Bluetooth signal connection is stable, and finally verified that it can be used for at least three hours.
Since the first generation AirPods have been used for a long time, the left ear airpods headphones can only be heard for less than half an hour. The right ear airpods have been replaced because they have been lost during the period, so now the left and right sides of the headphones are too far away. The use time is shortened, resulting in the impact of normal use, just to find a bad left earpod earphones, after testing the battery part and battery life is intact, so there are the following ideas and attempts to disassemble the airpods battery, Finally succeeded, share the tutorial for everyone to try, I hope to help friends who need it in itixit
Altre 17 persone hanno completato questa guida.
10 Commenti
Where I buy the battery for replacement, and how under what name?
I'm using a damaged headset, but the battery is good, and I took it out for repair. If you want a brand new original, it is only available in certain channels in China.
Deng lei -
Where can i buy an airpods battery…???
My location is Bangladesh,Asia.
Can i buy airpods battery in online???
You can try AliExpress:
Hola amigo, excelente el tutorial, sabes donde puedo comprar la batería? he buscado en canales de china pero no encuentro… mil gracias, espero tu respuesta.
Excellent where can I get batteries here in USA? Email me please hunterbuddy2017@hotmail.com
You can get new batteries on AliExpress at https://www.aliexpress.com/
Battery For Airpods 1st 2nd A1604 A1523 A1722 A2032 A2031 Air Pods 1 Air Pods 2 Replaceable Battery GOKY93mWhA1604 Battery
George -
Way too complicated. I would just buy new airpods!
