Salta al contenuto principale
Air Hog Smash Bots Controller Motherboard Replacement
Cosa ti serve
  1. Air Hog Smash Bots Controller Motherboard Replacement, Front Panel: passo 1, immagine 1 di 2 Air Hog Smash Bots Controller Motherboard Replacement, Front Panel: passo 1, immagine 2 di 2
    • Take out your controller and access to the back of the controller.
  2. Air Hog Smash Bots Controller Motherboard Replacement: passo 2, immagine 1 di 1
    • Remove the screw on the battery lid. Using the Hex 4 socket and PH #0 bit, remove the 8 mm screw.
  3. Air Hog Smash Bots Controller Motherboard Replacement: passo 3, immagine 1 di 1
    • Remove the 2 AAA batteries.
  4. Air Hog Smash Bots Controller Motherboard Replacement: passo 4, immagine 1 di 2 Air Hog Smash Bots Controller Motherboard Replacement: passo 4, immagine 2 di 2
    • Using the Hex 4 socket and PH #0 bit, remove the four 8 mm screws on the panel.
  5. Air Hog Smash Bots Controller Motherboard Replacement: passo 5, immagine 1 di 2 Air Hog Smash Bots Controller Motherboard Replacement: passo 5, immagine 2 di 2
    • Use the plastic opening tool to disconnect the front and back parts of the panel.
    • Some of the internal components may be displaced when opening the controller.
  6. Air Hog Smash Bots Controller Motherboard Replacement, Controller Motherboard: passo 6, immagine 1 di 2 Air Hog Smash Bots Controller Motherboard Replacement, Controller Motherboard: passo 6, immagine 2 di 2
    • Using the PH #0 bit, remove two 8 mm screws on the main board.
    • De-solder the LED wires from the motherboard.
    • Lift the motherboard with a spudger to remove it from the case.
Conclusione
IUPUI, Team 1-1, Baechle Spring 2016 Membro di IUPUI, Team 1-1, Baechle Spring 2016
IUPUI-BAECHLE-S16S1G1
4 Membri
14 Guide realizzate
Un commento
Hi,
Remot controller doesn't work.
Because my son used it into water.
So what should I do for fix it?
Thanks.
Ali Hori - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 172
