Introduzione
The trigger is the starting mechanism to shoot the darts from your blaster. You must be careful not to harm other parts of the blaster while taking out the trigger.
Cosa ti serve
Using a screwdriver, remove the two 11.6 mm phillips 00 screws holding the grey slider together.
Remove grey slider from the main body of the blaster.
Using a screwdriver, remove the six 9 mm phillips 00 screws holding the main body together.
Using the plastic opening tools, carefully take apart the main case of the blaster to leave the inside exposed.
Grab the orange trigger and without misplacing the other parts of the blaster, remove the trigger.
Altre 2 persone hanno completato questa guida.
