Salta al contenuto principale
Air Blasters Tek Six Barrel Replacement
Cosa ti serve
  1. Air Blasters Tek Six Barrel Replacement, Remove screws of the grey slider: passo 1, immagine 1 di 3 Air Blasters Tek Six Barrel Replacement, Remove screws of the grey slider: passo 1, immagine 2 di 3 Air Blasters Tek Six Barrel Replacement, Remove screws of the grey slider: passo 1, immagine 3 di 3
    • Using a screwdriver, remove the two 11.6 mm phillips 00 screws holding the grey slider together.
    • Remove grey slider from the main body of the blaster.
  2. Air Blasters Tek Six Barrel Replacement, Remove screws in main  body: passo 2, immagine 1 di 3 Air Blasters Tek Six Barrel Replacement, Remove screws in main  body: passo 2, immagine 2 di 3 Air Blasters Tek Six Barrel Replacement, Remove screws in main  body: passo 2, immagine 3 di 3
    • Using a screwdriver, remove the six 9 mm phillips 00 screws holding the main body together.
  3. Air Blasters Tek Six Barrel Replacement, Take the main body apart: passo 3, immagine 1 di 3 Air Blasters Tek Six Barrel Replacement, Take the main body apart: passo 3, immagine 2 di 3 Air Blasters Tek Six Barrel Replacement, Take the main body apart: passo 3, immagine 3 di 3
    • Using the plastic opening tools, carefully take apart the main case of the blaster to leave the inside exposed.
  4. Air Blasters Tek Six Barrel Replacement, Remove the trigger: passo 4, immagine 1 di 3 Air Blasters Tek Six Barrel Replacement, Remove the trigger: passo 4, immagine 2 di 3 Air Blasters Tek Six Barrel Replacement, Remove the trigger: passo 4, immagine 3 di 3
    • Remove the trigger, lifting from the bottom and pulling it out from under the metal pin.
  5. Air Blasters Tek Six Barrel Replacement, Removing the barrel: passo 5, immagine 1 di 3 Air Blasters Tek Six Barrel Replacement, Removing the barrel: passo 5, immagine 2 di 3 Air Blasters Tek Six Barrel Replacement, Removing the barrel: passo 5, immagine 3 di 3
    • Lift the barrel, pulling it out from under the black trigger catch
Conclusione
Joshua Taylor
Membro da: 09/22/14
118 Reputazione
1 Guida realizzata
USF Tampa, Team 3-1, Brown Fall 2014 Membro di USF Tampa, Team 3-1, Brown Fall 2014
USFT-BROWN-F14S3G1
3 Membri
5 Guide realizzate
Un commento
I don't remember this blaster's shell as being held closed by solvent weld or catches - why is the "iFixit" pry-tool necessary?
Arasin Staubly - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 14
Tutti i Tempi: 430
