Salta al contenuto principale
Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement
Cosa ti serve
  1. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement, Lens Assembly: passo 1, immagine 1 di 3 Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement, Lens Assembly: passo 1, immagine 2 di 3 Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement, Lens Assembly: passo 1, immagine 3 di 3
    • Remove the battery cover.
    • Remove the batteries.
  2. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: passo 2, immagine 1 di 1
    • Unscrew the three 4mm screws from the battery side of the device. Use a Phillips screw driver.
  3. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: passo 3, immagine 1 di 1
    • Remove the four screws from the back side.
  4. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: passo 4, immagine 1 di 2 Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: passo 4, immagine 2 di 2
    • Remove the sticky black dots.
    • Remove the hidden screw.
  5. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: passo 5, immagine 1 di 2 Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: passo 5, immagine 2 di 2
    • Remove the two screws from the top side of the device.
    • Remove the two screws from the bottom side of the device.
  6. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: passo 6, immagine 1 di 1
    • Remove the rear cover.
    • Be careful not to lose the spring inside.
  7. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: passo 7, immagine 1 di 1
    • Pull back the front cover so that you can dislodge the side cover.
  8. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: passo 8, immagine 1 di 1
    • Unfold the device and be careful not to tear the black and red power supply wires.
  9. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: passo 9, immagine 1 di 1
    • Remove the four screws from the motherboard.
  10. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: passo 10, immagine 1 di 1
    • Take out the motherboard while disconnecting the flip screen's cable from underneath.
  11. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: passo 11, immagine 1 di 1
    • Replace the Lens Assembly board.
    • Be careful not to damage any of the pins. Pull the board linearly.
Conclusione
USF Tampa, Team 6-4, Brown Winter 2015 Membro di USF Tampa, Team 6-4, Brown Winter 2015
USFT-BROWN-W15S6G4
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 127
