Salta al contenuto principale
Aiptek DZO-V58N Lens Replacement
Cosa ti serve
  1. Aiptek DZO-V58N Lens Replacement, Battery: passo 1, immagine 1 di 1
    • Locate the battery compartment on the back of the camera. It is the panel with the plastic ridges for simple removal.
    • Slide the battery compartment cover down off of the camera body.
  2. Aiptek DZO-V58N Lens Replacement: passo 2, immagine 1 di 1
    • Pry up the battery from the bottom using a finger and remove the batter from the case.
  3. Aiptek DZO-V58N Lens Replacement, Lens Protector: passo 3, immagine 1 di 1
    • Remove the lanyard by pulling the grey lace through the black string loop.
    • Pull black string loop through the silver bracket.
  4. Aiptek DZO-V58N Lens Replacement: passo 4, immagine 1 di 1
    • Use a plastic opening tool to pry off the black control cover.
    • The face plates are glued, so use force to pry the face plates from the camera body.
  5. Aiptek DZO-V58N Lens Replacement: passo 5, immagine 1 di 1
    • Use a plastic opening tool to pry off the ridged back face plate and the black button.
    • The button is loose and should come off with little or no effort.
  6. Aiptek DZO-V58N Lens Replacement: passo 6, immagine 1 di 1
    • Use a plastic opening tool to pry off the silver face plate.
  7. Aiptek DZO-V58N Lens Replacement: passo 7, immagine 1 di 3 Aiptek DZO-V58N Lens Replacement: passo 7, immagine 2 di 3 Aiptek DZO-V58N Lens Replacement: passo 7, immagine 3 di 3
    • Open the USB cover to expose the small machine screw.
    • Use the Phillips #00 screwdriver to unscrew the six 0.5cm machine case screws (distributed around the camera body).
    • These small screws are easy to lose. Place the removed screws in an organized container to avoid losing them.
  8. Aiptek DZO-V58N Lens Replacement: passo 8, immagine 1 di 1
    • Pull off the side control panel.
  9. Aiptek DZO-V58N Lens Replacement: passo 9, immagine 1 di 2 Aiptek DZO-V58N Lens Replacement: passo 9, immagine 2 di 2
    • Flip open the screen by pulling the loose end of the screen away from the case.
    • Use tweezers to remove the two outside rubber dots to reveal the two 0.5cm machine screws.
    • Use the #00 Phillips Screwdriver to remove both screws.
  10. Aiptek DZO-V58N Lens Replacement: passo 10, immagine 1 di 2 Aiptek DZO-V58N Lens Replacement: passo 10, immagine 2 di 2
    • Pull the body apart from the bottom of device just enough to make space to remove the silver plastic strap holder.
    • Use tweezers to remove the silver plastic strap holder.
    • Use a plastic opening tool to pry off the lens protector.
  11. Aiptek DZO-V58N Lens Replacement, Lens: passo 11, immagine 1 di 3 Aiptek DZO-V58N Lens Replacement, Lens: passo 11, immagine 2 di 3 Aiptek DZO-V58N Lens Replacement, Lens: passo 11, immagine 3 di 3
    • Unscrew the two silver 0.5cm machine screws with the #00 Phillips screwdriver.
    • Lift off the lens protector housing.
    • Pull apart the two halves of the camera body.
    • Do not pull the two halves apart too far because the wires may detach.
  12. Aiptek DZO-V58N Lens Replacement: passo 12, immagine 1 di 1
    • Unscrew both black machine screws holding the lens in place with the #00 Phillips screwdriver.
  13. Aiptek DZO-V58N Lens Replacement: passo 13, immagine 1 di 1
    • Carefully remove the compressed springs underneath each of the two screws that were removed in the previous step.
    • Be careful not to lose the springs. The springs are in compression and will launch from the camera if not held onto.
  14. Aiptek DZO-V58N Lens Replacement: passo 14, immagine 1 di 1
    • Lift off the lens.
Conclusione
Cal Poly, Team 5-5, Forte Spring 2012 Membro di Cal Poly, Team 5-5, Forte Spring 2012
CPSU-FORTE-S12S5G5
5 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 528
