Salta al contenuto principale
Acer Aspire One D150 Memory Upgrade Replacement
Cosa ti serve
  1. Acer Aspire One D150 Memory Upgrade Replacement, Memory Upgrade: passo 1, immagine 1 di 1
    • Be sure computer is unplugged, turned off, and battery is removed.
    • Then, locate memory door and remove screw with #0 Phillips screw driver.
  2. Acer Aspire One D150 Memory Upgrade Replacement: passo 2, immagine 1 di 1
    • If needed, pry open door using knife or flat screw driver.
  3. Acer Aspire One D150 Memory Upgrade Replacement: passo 3, immagine 1 di 3 Acer Aspire One D150 Memory Upgrade Replacement: passo 3, immagine 2 di 3 Acer Aspire One D150 Memory Upgrade Replacement: passo 3, immagine 3 di 3
    • Remove plastic door to expose lone memory DIMM.
    • Press two metal clasps on both sides of the DIMM apart to allow memory module to pop up.
  4. Acer Aspire One D150 Memory Upgrade Replacement: passo 4, immagine 1 di 1
    • Head over to Newegg and buy yourself a 2gb DDR2, 667mhz laptop memory to install in your Aspire One.
Conclusione
Altre 11 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 10
Tutti i Tempi: 21,256
