Salta al contenuto principale
Afterglow Wireless PS3 Controller Button Replacement
Cosa ti serve
  1. Afterglow Wireless PS3 Controller Button Replacement, Back Cover: passo 1, immagine 1 di 2 Afterglow Wireless PS3 Controller Button Replacement, Back Cover: passo 1, immagine 2 di 2
    • Lay the controller face down on a flat surface and remove the seven 9mm Phillips #0 screws on the back of the controller.
    • Lift up and remove the controller back plate.
  2. Afterglow Wireless PS3 Controller Button Replacement, Button: passo 2, immagine 1 di 2 Afterglow Wireless PS3 Controller Button Replacement, Button: passo 2, immagine 2 di 2
    • Carefully remove the battery by lifting it straight up from its place.
    • Keep in mind that the red and black battery wires are attached to the motherboard. Handle these with care.
  3. Afterglow Wireless PS3 Controller Button Replacement: passo 3, immagine 1 di 1
    • Unscrew the four 9mm Phillips #0 screws that are attached to both joy stick control mini-motherboards. There are two screws for each mini-motherboard.
  4. Afterglow Wireless PS3 Controller Button Replacement: passo 4, immagine 1 di 2 Afterglow Wireless PS3 Controller Button Replacement: passo 4, immagine 2 di 2
    • Jiggle both joy stick control mini-motherboards out of their holding place.
    • Set aside the mini-motherboards so you can access the main motherboard.
  5. Afterglow Wireless PS3 Controller Button Replacement: passo 5, immagine 1 di 2 Afterglow Wireless PS3 Controller Button Replacement: passo 5, immagine 2 di 2
    • Pull both vibration motors straight up from their holding place.
  6. Afterglow Wireless PS3 Controller Button Replacement: passo 6, immagine 1 di 2 Afterglow Wireless PS3 Controller Button Replacement: passo 6, immagine 2 di 2
    • Unscrew the two 9mm Phillips #0 screws holding the motherboard to the controller front plate.
  7. Afterglow Wireless PS3 Controller Button Replacement: passo 7, immagine 1 di 2 Afterglow Wireless PS3 Controller Button Replacement: passo 7, immagine 2 di 2
    • Detach the main motherboard fom the front pate by carefully pulling it off.
    • Be careful of the trigger buttons when pulling out the motherboard. The buttons have mini-motherboards secured in place on the front plate. Carefully pull these out.
  8. Afterglow Wireless PS3 Controller Button Replacement: passo 8, immagine 1 di 3 Afterglow Wireless PS3 Controller Button Replacement: passo 8, immagine 2 di 3 Afterglow Wireless PS3 Controller Button Replacement: passo 8, immagine 3 di 3
    • Pick up the controller front plate and carefully turn it over so that the buttons left in it will fall out.
    • You may want to flip it while holding it over a container so the buttons do not go bouncing away from your work space.
Conclusione
Altre 3 persone hanno completato questa guida.
Aj Coello
Membro da: 02/17/17
1.014 Reputazione
6 Guide realizzate
USF Tampa, Team S19-G5, Hoffman Spring 2017 Membro di USF Tampa, Team S19-G5, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G5
4 Membri
20 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 65
Tutti i Tempi: 1,959
