Salta al contenuto principale
Afridev Tank Replacement
Cosa ti serve
  1. Afridev Tank Replacement, Head: passo 1, immagine 1 di 2 Afridev Tank Replacement, Head: passo 1, immagine 2 di 2
    • Assemble the required tools, including the Afridev tool and crescent wrenches.
  2. Afridev Tank Replacement: passo 2, immagine 1 di 3 Afridev Tank Replacement: passo 2, immagine 2 di 3 Afridev Tank Replacement: passo 2, immagine 3 di 3
    • Perform a water test on the pump, by raising and lowering the handle a full 40 strokes. A properly performing pump will yield greater than 10 liters.
  3. Afridev Tank Replacement: passo 3, immagine 1 di 2 Afridev Tank Replacement: passo 3, immagine 2 di 2
    • Loosen the bolt on front of the face plate with the Afridev tool.
    • Remove the plate from the pump by lifting it straight up.
  4. Afridev Tank Replacement, Axle and Handle: passo 4, immagine 1 di 3 Afridev Tank Replacement, Axle and Handle: passo 4, immagine 2 di 3 Afridev Tank Replacement, Axle and Handle: passo 4, immagine 3 di 3
    • Insert the T-handle into the top cylinder of the exposed pump rod.
  5. Afridev Tank Replacement: passo 5, immagine 1 di 2 Afridev Tank Replacement: passo 5, immagine 2 di 2
    • Loosen the 2 bolts on either side of handle.
    • It is not necessary to remove the bolt at this time; however, take caution to not let the bolt fall out of the handle.
  6. Afridev Tank Replacement: passo 6, immagine 1 di 3 Afridev Tank Replacement: passo 6, immagine 2 di 3 Afridev Tank Replacement: passo 6, immagine 3 di 3
    • Loosen the 2 bolts on either side of the head to remove the handle from the pump rod.
  7. Afridev Tank Replacement: passo 7, immagine 1 di 2 Afridev Tank Replacement: passo 7, immagine 2 di 2
    • Lift the handle to a horizontal position.
  8. Afridev Tank Replacement: passo 8, immagine 1 di 3 Afridev Tank Replacement: passo 8, immagine 2 di 3 Afridev Tank Replacement: passo 8, immagine 3 di 3
    • While one person lifts up on the T-handle, remove the bolt and connection pieces.
  9. Afridev Tank Replacement: passo 9, immagine 1 di 3 Afridev Tank Replacement: passo 9, immagine 2 di 3 Afridev Tank Replacement: passo 9, immagine 3 di 3
    • Remove the bolt and connection pieces from the handle.
    • Set the bolt pieces in a sanitary place, such as a bucket, to prevent contamination.
  10. Afridev Tank Replacement: passo 10, immagine 1 di 2 Afridev Tank Replacement: passo 10, immagine 2 di 2
    • Remove the handle from the pump.
    • Be sure to set the handle in a sanitary place to prevent contamination.
  11. Afridev Tank Replacement, Pump Rod: passo 11, immagine 1 di 2 Afridev Tank Replacement, Pump Rod: passo 11, immagine 2 di 2
    • Grab firmly on the T-handle and lift the pump rod straight up.
    • Expose the first connection of the pump rod, and support the portion below the connection.
  12. Afridev Tank Replacement: passo 12, immagine 1 di 2 Afridev Tank Replacement: passo 12, immagine 2 di 2
    • While holding the pump rod below the first connection tightly, lower the first portion of the rod to a horizontal position.
  13. Afridev Tank Replacement: passo 13, immagine 1 di 3 Afridev Tank Replacement: passo 13, immagine 2 di 3 Afridev Tank Replacement: passo 13, immagine 3 di 3
    • Unhook the first connection by pushing it out and down, then pulling it away from the rest of the rod.
  14. Afridev Tank Replacement: passo 14, immagine 1 di 3 Afridev Tank Replacement: passo 14, immagine 2 di 3 Afridev Tank Replacement: passo 14, immagine 3 di 3
    • Repeat steps 11-13 for the remaining sections of pump rod.
    • Be sure to set the pump rod segments above the ground to avoid contamination.
  15. Afridev Tank Replacement, Tank: passo 15, immagine 1 di 2 Afridev Tank Replacement, Tank: passo 15, immagine 2 di 2
    • Place one wrench on the top side of the top base of the tank spout.
    • Place another wrench on the underside of the bolt in order to get more leverage.
    • Pull the top wrench to the right, and the bottom wrench to the left.
  16. Afridev Tank Replacement: passo 16, immagine 1 di 3 Afridev Tank Replacement: passo 16, immagine 2 di 3 Afridev Tank Replacement: passo 16, immagine 3 di 3
    • Remove the loosened bolt from the pump.
    • Repeat this procedure for the 3 remaining bolts.
  17. Afridev Tank Replacement: passo 17, immagine 1 di 2 Afridev Tank Replacement: passo 17, immagine 2 di 2
    • Lift the tank straight up to remove it from the pump.
    • Be sure to place the tank in a sanitary place to prevent contamination.
Conclusione
Jake Devincenzi
Membro da: 04/18/11
117.271 Reputazione
57 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 305
