Salta al contenuto principale
Afridev Axle and Handle Replacement
Cosa ti serve
  1. Afridev Axle and Handle Replacement, Head: passo 1, immagine 1 di 2 Afridev Axle and Handle Replacement, Head: passo 1, immagine 2 di 2
    • Assemble the required tools, including the Afridev tool and crescent wrenches.
  2. Afridev Axle and Handle Replacement: passo 2, immagine 1 di 3 Afridev Axle and Handle Replacement: passo 2, immagine 2 di 3 Afridev Axle and Handle Replacement: passo 2, immagine 3 di 3
    • Perform a water test on the pump, by raising and lowering the handle a full 40 strokes. A properly performing pump will yield greater than 10 liters.
  3. Afridev Axle and Handle Replacement: passo 3, immagine 1 di 2 Afridev Axle and Handle Replacement: passo 3, immagine 2 di 2
    • Loosen the bolt on front of the face plate with the Afridev tool.
    • Remove the plate from the pump by lifting it straight up.
  4. Afridev Axle and Handle Replacement, Axle and Handle: passo 4, immagine 1 di 3 Afridev Axle and Handle Replacement, Axle and Handle: passo 4, immagine 2 di 3 Afridev Axle and Handle Replacement, Axle and Handle: passo 4, immagine 3 di 3
    • Insert the T-handle into the top cylinder of the exposed pump rod.
  5. Afridev Axle and Handle Replacement: passo 5, immagine 1 di 2 Afridev Axle and Handle Replacement: passo 5, immagine 2 di 2
    • Loosen the 2 bolts on either side of handle.
    • It is not necessary to remove the bolt at this time; however, take caution to not let the bolt fall out of the handle.
  6. Afridev Axle and Handle Replacement: passo 6, immagine 1 di 3 Afridev Axle and Handle Replacement: passo 6, immagine 2 di 3 Afridev Axle and Handle Replacement: passo 6, immagine 3 di 3
    • Loosen the 2 bolts on either side of the head to remove the handle from the pump rod.
  7. Afridev Axle and Handle Replacement: passo 7, immagine 1 di 2 Afridev Axle and Handle Replacement: passo 7, immagine 2 di 2
    • Lift the handle to a horizontal position.
  8. Afridev Axle and Handle Replacement: passo 8, immagine 1 di 3 Afridev Axle and Handle Replacement: passo 8, immagine 2 di 3 Afridev Axle and Handle Replacement: passo 8, immagine 3 di 3
    • While one person lifts up on the T-handle, remove the bolt and connection pieces.
  9. Afridev Axle and Handle Replacement: passo 9, immagine 1 di 3 Afridev Axle and Handle Replacement: passo 9, immagine 2 di 3 Afridev Axle and Handle Replacement: passo 9, immagine 3 di 3
    • Remove the bolt and connection pieces from the handle.
    • Set the bolt pieces in a sanitary place, such as a bucket, to prevent contamination.
  10. Afridev Axle and Handle Replacement: passo 10, immagine 1 di 2 Afridev Axle and Handle Replacement: passo 10, immagine 2 di 2
    • Remove the handle from the pump.
    • Be sure to set the handle in a sanitary place to prevent contamination.
Conclusione
Jake Devincenzi
Membro da: 04/18/11
118.792 Reputazione
57 Guide realizzate
2Commenti sulla guida
J'ai besoin de pompe
Sylvain Monga - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 16
Tutti i Tempi: 825
