Introduzione
Just taking apart my Aether Cone!
Cosa ti serve
It is held on with some double sided adhesive tape, just peel it back carefully from a corner
Then remove all the screws shown in the picture
Next remove the small circuit board on the end of the silver ribbon cable, it is held on with some more double sided adhesive
Then remove the two allen head bolts hidden inside the case that hold the outer casing to the mid frame.
Remove the ribbon cable and the connector holding the case to the mid frame
undo the screws that hold the metal bracket in place and then disconnect the battery.
The battery can then be gently pulled off the mid frame as it is held on by double sided adhesive foam tape.
The battery is a 7.2v 5200mah battery consisting of 4 18650 cells.
remove the screws and the main circuit board can be taken off the mid frame.
Hopefully the photos can help with identifying the chips
remove all the long screws around the mid frame
The midframe can then be lifted off
this then reveals the two tweeters and the 3 inch driver which provides the excellent sound quality.
Altre 6 persone hanno completato questa guida.
9 Commenti
it would be great to get access to the firmware to enable the microphone and make it work as an assistant via Google API or Alexa API
I also want to know if this is possible.
I’ve got four of these around the house but connected via bluetooth (which is pretty unstable) they are not in sync.
Would be great to be able to plug directly into an amazon dot?
Any suggestions for a work around would be great?
Mine has stopped charging so is only usable plugged in. Is this a common problem can it be fixed easily? I checked various voltages on the battery board but cant find any reference to what they should be.
Mine stopped charging too. I just changed all the batteries and it all works fine again now.
