Salta al contenuto principale
AeraMax Pro AM III Air Filter Replacement
Documento in evidenza
  1. AeraMax Pro AM III Air Filter Replacement, Air Filter: passo 1, immagine 1 di 3 AeraMax Pro AM III Air Filter Replacement, Air Filter: passo 1, immagine 2 di 3 AeraMax Pro AM III Air Filter Replacement, Air Filter: passo 1, immagine 3 di 3
    • If the access panel is locked, use the key to unlock it and open it by pressing the levers on both sides.
    • The appliance can open only if both levers are pressed simultaneously.
    • Use your hands to remove the old filter.
  2. AeraMax Pro AM III Air Filter Replacement: passo 2, immagine 1 di 3 AeraMax Pro AM III Air Filter Replacement: passo 2, immagine 2 di 3 AeraMax Pro AM III Air Filter Replacement: passo 2, immagine 3 di 3
    • When removing the old filter, do not throw away the filter cage. Wipe it down and prepare to use it for the new filter.
    • If you have not already wiped down your appliance, give it a thorough wipe-down with your preferred cleaning product.
  3. AeraMax Pro AM III Air Filter Replacement: passo 3, immagine 1 di 3 AeraMax Pro AM III Air Filter Replacement: passo 3, immagine 2 di 3 AeraMax Pro AM III Air Filter Replacement: passo 3, immagine 3 di 3
    • Remove the plastic from the new HEPA filter and place it into the filter cage.
  4. AeraMax Pro AM III Air Filter Replacement: passo 4, immagine 1 di 3 AeraMax Pro AM III Air Filter Replacement: passo 4, immagine 2 di 3 AeraMax Pro AM III Air Filter Replacement: passo 4, immagine 3 di 3
    • Insert the carbon filter into the filter cage that you wiped down and make sure the corners are aligned with the filter cage.
    • Take your new HEPA filter and make sure the stickers are aligned and the corners of the pre-filter are fleshed down until it sticks to the carbon filter.
  5. AeraMax Pro AM III Air Filter Replacement: passo 5, immagine 1 di 3 AeraMax Pro AM III Air Filter Replacement: passo 5, immagine 2 di 3 AeraMax Pro AM III Air Filter Replacement: passo 5, immagine 3 di 3
    • Insert your filter cage back into the access panel and make sure that the filter label is visible and facing upwards.
    • You can give your appliance one more wipe-down to ensure cleanliness.
  6. AeraMax Pro AM III Air Filter Replacement: passo 6, immagine 1 di 3 AeraMax Pro AM III Air Filter Replacement: passo 6, immagine 2 di 3 AeraMax Pro AM III Air Filter Replacement: passo 6, immagine 3 di 3
    • Press the HEPA Setting for three seconds until the icon turns green.
    • The green icon indicates that the filter has been replaced and is ready to be used.
    • Close the access panel.
Linea Traguardo
Documenti Allegati
Pita Vaouli
Membro da: 08/22/22
157 Reputazione
1 Guida realizzata
Un commento
I have a brand new Air purifier just like the one in your demonstration I would like to sell, it's still in the box. I don't know how much to ask for it or where I can sell it. Can you help me?
Danette Dinot - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 211
