Salta al contenuto principale
Adjusting the front bonnet
Cosa ti serve
  1. Adjusting the front bonnet, Locate the closing mechanism on the bonnet: passo 1, immagine 1 di 1
    • Open the bonnet from the inside of the car (use the lever in the glove-box) and raise the bonnet completely open.
    • The 13mm screw used to adjust the closing mechanism of the bonnet. This is the one that probably needs adjustment
    • Screws which secure the mechanism to the bonnet
    • Spring which raises the bonnet slightly so that it can be further opened by hand
  2. Adjusting the front bonnet, Adjust closing mechanism using the screw: passo 2, immagine 1 di 1
    • Use the 13mm Wrench to screw/unscrew the bonnet closing mechanism so that it gets adjusted. Usually it needs unscrewing a little so that it reaches the closing mechanism on the car.
    • The missing black paint on the screw indicates how much this bonnet closing mechanism needed adjustment
    • After adjusting, if unscrewing was needed and the closing mechanism screw shows unpainted parts it would be wise to spray-paint the area to protect from corrosion/rust in the future.
Conclusione
After adjustment the front bonnet should fully close easily when lowering.
Altre 3 persone hanno completato questa guida.
Dan Mihai Ile
Membro da: 10/16/12
186 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 26
Tutti i Tempi: 4,497
