Salta al contenuto principale
Adjusting the alarm glass breakage microphone sensitivity
Cosa ti serve
  1. Adjusting the alarm glass breakage microphone sensitivity: passo 2, immagine 1 di 1
    • Once the glove box is out of the way, it's easy to spot the alarm unit. The green connector will be plugged into it. I had already unplugged it when I took this picture.
  2. Adjusting the alarm glass breakage microphone sensitivity: passo 3, immagine 1 di 1
    • It may be stubborn to get out because it is stuck down with double stick foam pads.
  3. Adjusting the alarm glass breakage microphone sensitivity: passo 4, immagine 1 di 1
    • Remove the 4 screws (may be under the foam strips). This is the bottom of the circuit board.
  4. Adjusting the alarm glass breakage microphone sensitivity: passo 5, immagine 1 di 1
    • Turn the board over and locate the 2 position dip switch.
    • This dip switch adjusts the glass breakage microphone sensitivity
    • Sensitivity settings:
    • 1 off & 2 off = high
    • 1 on & 2 off = mid (factory setting)
    • 1 off & 2 on = low
    • 1 on & 2 on = super low
Conclusione
Altre 3 persone hanno completato questa guida.
mpeeples
Membro da: 04/04/10
184 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 16
Tutti i Tempi: 2,559
