Introduzione
The alarm unit is located behind the glove box. Once the glovebox is out of the way, you can remove the black plastic alarm unit, open it and change the dip switch for a less sensitive setting.
Parti
Nessuna parte richiesta.
  1. Once the glove box is out of the way, it's easy to spot the alarm unit. The green connector will be plugged into it. I had already unplugged it when I took this picture.
    • Once the glove box is out of the way, it's easy to spot the alarm unit. The green connector will be plugged into it. I had already unplugged it when I took this picture.
  2. Spedizione gratuita per tutti gli ordini superiori a 100,00 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  3. It may be stubborn to get out because it is stuck down with double stick foam pads.
    • It may be stubborn to get out because it is stuck down with double stick foam pads.
  4. Remove the 4 screws (may be under the foam strips). This is the bottom of the circuit board.
    • Remove the 4 screws (may be under the foam strips). This is the bottom of the circuit board.
  5. Turn the board over and locate the 2 position dip switch.
    • Turn the board over and locate the 2 position dip switch.
    • This dip switch adjusts the glass breakage microphone sensitivity
    • Sensitivity settings:
    • 1 off & 2 off = high
    • 1 on & 2 off = mid (factory setting)
    • 1 off & 2 on = low
    • 1 on & 2 on = super low
Conclusione
Altre 3 persone hanno completato questa guida.
mpeeples
Membro da: 04/04/2010
184 Reputazione
1 Guida realizzata
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,846
