Salta al contenuto principale
Adjusting the Weight of a Logitech G502 Hero
  1. Adjusting the Weight of a Logitech G502 Hero, Adjusting the Weight of a Logitech G502 Hero: passo 1, immagine 1 di 1
    • Unplug the mouse from your computer
  2. Adjusting the Weight of a Logitech G502 Hero: passo 2, immagine 1 di 1
    • Turn the mouse so that the bottom of the mouse is upright.
  3. Adjusting the Weight of a Logitech G502 Hero: passo 3, immagine 1 di 2 Adjusting the Weight of a Logitech G502 Hero: passo 3, immagine 2 di 2
    • Use your fingers to lift the magnetic backplate away from the mouse.
  4. Adjusting the Weight of a Logitech G502 Hero: passo 4, immagine 1 di 2 Adjusting the Weight of a Logitech G502 Hero: passo 4, immagine 2 di 2
    • A set of weights are included with the device in a small black box.
    • Adjust the weights by putting in as many weights as you desire.
    • Each one weighs 3.6g. If you're not sure where to place the weights, use the second picture as a guide.
  5. Adjusting the Weight of a Logitech G502 Hero: passo 5, immagine 1 di 2 Adjusting the Weight of a Logitech G502 Hero: passo 5, immagine 2 di 2
    • Snap the magnetic plate back in the mouse.
Conclusione
Altre 4 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 41
Ultimi 30 Giorni: 174
Tutti i Tempi: 5,768
