Salta al contenuto principale
Adjusting Nishiki Aero II Seat
Cosa ti serve
  1. Adjusting Nishiki Aero II Seat, Adjusting Nishiki Aero II Seat: passo 1, immagine 1 di 3 Adjusting Nishiki Aero II Seat, Adjusting Nishiki Aero II Seat: passo 1, immagine 2 di 3 Adjusting Nishiki Aero II Seat, Adjusting Nishiki Aero II Seat: passo 1, immagine 3 di 3
    • Loosen the bolt that secures your seat.
    • To do so, use one wrench to hold the larger nut on the left side of the bike still while you loosen the nut on the right.
  2. Adjusting Nishiki Aero II Seat: passo 2, immagine 1 di 2 Adjusting Nishiki Aero II Seat: passo 2, immagine 2 di 2
    • Now that it can move, move the seat by wiggling it and pulling it in the direction you want to adjust it.
    • You want to the adjust the seat so that, when a pedal is at the far end of its rotation, your leg is fully extended.
    • Don't worry about getting it perfect on the first try. Instead, guess your adjustment, tighten the bolt a little bit, try it out, and adjust again until you get it right.
  3. Adjusting Nishiki Aero II Seat: passo 3, immagine 1 di 1
    • Once your seat is at the desired height, you just tighten the bolt the same way you loosened it.
    • Use two wrenches, one to hold it still and the other to tighten the nut.
    • Make sure it's very tight, or else the seat might twist or lower over time.
Conclusione
Tobias Elder
Membro da: 04/25/13
113 Reputazione
7 Guide realizzate
Cal Poly, Team 21-53, Johann Spring 2013 Membro di Cal Poly, Team 21-53, Johann Spring 2013
CPSU-JOHANN-S13S21G53
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 29
Tutti i Tempi: 2,777
