Salta al contenuto principale
Adjusting Nishiki Aero II Front Derailleur
Cosa ti serve
  1. Adjusting Nishiki Aero II Front Derailleur, Adjusting Nishiki Aero II Front Derailleur: passo 1, immagine 1 di 1
    • Shift the bike's rear derailleur onto the innermost gear.
  2. Adjusting Nishiki Aero II Front Derailleur: passo 2, immagine 1 di 1
    • Shift the front derailleur as far inward as it can go.
    • If the chain falls off, tighten the outside limit screw on top of the derailleur.
    • If the chain can't shift to the lower gear, loosen the outside limit screw on top of the derailleur.
    • Yes, the outer limit screw adjusts the inner derailleur limit.
  3. Adjusting Nishiki Aero II Front Derailleur: passo 3, immagine 1 di 1
    • Next, shift the rear derailleur onto the outermost gear.
  4. Adjusting Nishiki Aero II Front Derailleur: passo 4, immagine 1 di 1
    • Shift the front derailleur as far outwards as you can.
    • If the derailleur shifts the chain off the gear, tighten the inner limit screw on top of the front derailleur.
    • If the derailleur is unable to shift onto the outer gear, loosen the inner limit screw on top of the front derailleur.
    • Just like last time, the inner limit screw adjusts the outer limit of the derailleur.
Conclusione
Now, your bike shouldn't have any more problems with the chain falling off.
Tobias Elder
Membro da: 04/25/13
113 Reputazione
7 Guide realizzate
Cal Poly, Team 21-53, Johann Spring 2013 Membro di Cal Poly, Team 21-53, Johann Spring 2013
CPSU-JOHANN-S13S21G53
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,881
