Introduzione
The front and rear derailleurs (pronounced "derailer" but spelled this way because of the French) are what move the bike's chain back and forth across your gear sets, allowing you to shift between different gear combinations and thus handle a variety of speeds and inclines.
However, in order for the derailleur to work properly, it needs to be adjusted so that it's shifting over the correct range. That's what this guide will show you how to do.
Cosa ti serve
Shift the bike's rear derailleur onto the innermost gear.
Shift the front derailleur as far outwards as you can.
If the derailleur shifts the chain off the gear, tighten the inner limit screw on top of the front derailleur.
If the derailleur is unable to shift onto the outer gear, loosen the inner limit screw on top of the front derailleur.
Just like last time, the inner limit screw adjusts the outer limit of the derailleur.
Now, your bike shouldn't have any more problems with the chain falling off.
