Salta al contenuto principale
Adjust Goose-neck (adjustable quill stem) on Specialized Expedition
Cosa ti serve
  1. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition, Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: passo 1, immagine 1 di 2 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition, Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: passo 1, immagine 2 di 2
    • Remove the bolt cover with a flathead screwdriver.
  2. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: passo 2, immagine 1 di 3 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: passo 2, immagine 2 di 3 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: passo 2, immagine 3 di 3
    • Loosen the goose-neck (adjustable quill stem) with a 6 mm Allen wrench.
    • After loosening the goose-neck (adjustable quill stem), it still may be stiff. Hold the wheel from turning and twist the handlebars from side to side.
    • If quill stem is still stuck then place 6 mm Allen wrench firmly into bolt and tap with a mallet.
    • Position the handlebars to your preferred height. Make sure not to pull cable and housing to tight. I could adversely effect shifting and braking performance.
    • Make sure you don't raise quill stem above minimum insert line.
  3. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: passo 3, immagine 1 di 3 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: passo 3, immagine 2 di 3 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: passo 3, immagine 3 di 3
    • Align the direction of the goose-neck (adjustable quill stem) with the front tire.
    • Firmly tighten the goose-neck (adjustable quill stem) bolt using a 6 mm Allen wrench.
    • Pop the bolt cover back on.
    • If calling a bicycle repair shop, refer to it as a adjustable quill stem (technical term) instead of goose-neck as mechanic may not know what you are talking about.
Linea Traguardo
aaron thielk
Membro da: 10/10/10
1.882 Reputazione
5 Guide realizzate
Cal Poly, Team 5-13, Maness Fall 2010 Membro di Cal Poly, Team 5-13, Maness Fall 2010
CPSU-MANESS-F10S5G13
4 Membri
17 Guide realizzate
Un commento
Anyone know where/how to buy a replacement bolt cover?
Bennett Hart - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 10
Tutti i Tempi: 9,221
