Introduzione
Use this guide for replacing the worn out studs on your cleats (Ex. Adidas, Crazyquick Football Cleat).
If you see that your studs on your cleats are either shortening or becoming uneven, it may be time to replace those worn out studs. Before you begin replacing the studs, you must check to see the studs can be replaced. The best way to check is to count how many studs you have, typically cleats with replaceable studs have 7 studs.
In order to proceed with replacing the studs, you must have the replacement studs and the stud wrench that helps tightening/ loosening of the studs which can be purchased here.
Cosa ti serve
