Salta al contenuto principale
AcuRite 02081M Observer Repair Battery,LCD Screen,Push Button Replacement
Cosa ti serve
  1. AcuRite 02081M Observer Repair Battery,LCD Screen,Push Button Replacement, Battery Replacement: passo 1, immagine 1 di 1
    • First, unscrew the 4 M2x1.5-7 screws (7mm length) from the back of the device using a number 1 Phillips screwdriver.
    • Pry the front silver panel away from the back black panel with a plastic opening tool.
  2. AcuRite 02081M Observer Repair Battery,LCD Screen,Push Button Replacement, Step 2: passo 2, immagine 1 di 1
    • Next, the ribbon cable needs to be carefully removed from the back of the LCD screen.
    • Use a plastic opening tool to press the black bar towards the ribbon and away from the white bar gently. This will release the ribbon.
  3. AcuRite 02081M Observer Repair Battery,LCD Screen,Push Button Replacement, step 3: passo 3, immagine 1 di 1
    • Remove the 4 M2x1.5-7 screws (7mm length) from the green PCB board.
    • This will result in two pieces, the back black cover and the PCB board.
  4. AcuRite 02081M Observer Repair Battery,LCD Screen,Push Button Replacement: passo 4, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • The battery can then be popped out using precision tweezers and replaced with a new one.
Conclusione
anhut51190
Membro da: 07/04/19
281 Reputazione
2 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 18
Tutti i Tempi: 231
