Salta al contenuto principale
Acer TravelMate P653-V-6882 RAM Replacement
Cosa ti serve
  1. Acer TravelMate P653-V-6882 RAM Replacement, Battery Pack: passo 1, immagine 1 di 2 Acer TravelMate P653-V-6882 RAM Replacement, Battery Pack: passo 1, immagine 2 di 2
    • Turn the computer over so the base is facing up.
    • Slide the battery lock to unlock position.
  2. Acer TravelMate P653-V-6882 RAM Replacement: passo 2, immagine 1 di 1
    • Slide the battery release latch to the right.
    • The battery pack will pop out.
  3. Acer TravelMate P653-V-6882 RAM Replacement: passo 3, immagine 1 di 1
    • Lift the battery up.
    • Pull out the battery.
  4. Acer TravelMate P653-V-6882 RAM Replacement, Base Door: passo 4, immagine 1 di 1
    • Remove the five 7mm Phillips #1 screws.
  5. Acer TravelMate P653-V-6882 RAM Replacement: passo 5, immagine 1 di 1
    • Use the opening tool to separate base door from the bottom of the laptop.
    • Be careful not to bend or crack the plastic back cover.
  6. Acer TravelMate P653-V-6882 RAM Replacement: passo 6, immagine 1 di 2 Acer TravelMate P653-V-6882 RAM Replacement: passo 6, immagine 2 di 2
    • Gently pry open the base door by pushing up.
    • Pull out the base door.
  7. Acer TravelMate P653-V-6882 RAM Replacement, RAM: passo 7, immagine 1 di 1
    • Locate the two RAM sticks on the bottom of the laptop.
  8. Acer TravelMate P653-V-6882 RAM Replacement: passo 8, immagine 1 di 3 Acer TravelMate P653-V-6882 RAM Replacement: passo 8, immagine 2 di 3 Acer TravelMate P653-V-6882 RAM Replacement: passo 8, immagine 3 di 3
    • Pinch the two metal pieces holding the RAM sticks in place outwards.
    • Holding the sides of the RAM, slide the RAM sticks out.
    • Be careful not to touch the gold connection pins on the RAM sticks, as this could damage the RAM
Conclusione
Basel Kandil
Membro da: 01/18/20
85 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 204
