Introduzione
Whether your Acer TravelMate P653-V-6882 begins to overheat, you need to access the I/O ports, or replace the LCD module, then you must remove the mainboard, also known as the motherboard.
Here is a guide on how to access the TravelMate’s mainboard (motherboard), where you then can begin to either remove it and fix any issues you are facing with the internals.
Cosa ti serve
Turn the computer over so the base is facing up.
Slide the battery lock to unlock position.
Turn the computer over, open the LCD panel, and find the smart card cable connector.
Open the smart card cable connector latch.
Disconnect the cable.
Flip the laptop so that the underside is now facing the bottom.
Open the LCD panel.
Locate the small gaps between the upper cover and lower case on the left and right side of the laptop.
Insert the opening tool into each gap to separate the one from the other.
Once the upper cover is separated, lift it from the lower case.
