Salta al contenuto principale
Acer Spin 7 SP714-51 Wi-Fi Card Replacement
Cosa ti serve
  1. Acer Spin 7 SP714-51 Wi-Fi Card Replacement, Wi-Fi Card: passo 1, immagine 1 di 3 Acer Spin 7 SP714-51 Wi-Fi Card Replacement, Wi-Fi Card: passo 1, immagine 2 di 3 Acer Spin 7 SP714-51 Wi-Fi Card Replacement, Wi-Fi Card: passo 1, immagine 3 di 3
    • Turn the laptop so that the back cover is visible and facing you. Make sure it is on a flat surface, such as a table.
    • Using a standard PH0 Phillips-head screwdriver, work your way around the edge removing the 6mm screws along the way.
    • Once all the screws are removed, you should easily be able to remove the back cover. This can be done by hand or by using a Spudger as seen in the tools list.
    • Once the back cover is removed, make sure you disconnect the battery cable.
  2. Acer Spin 7 SP714-51 Wi-Fi Card Replacement: passo 2, immagine 1 di 1
    • Disconnect the white and black antennae from the Wi-Fi card.
    • The Wi-Fi card is located on the left side of the laptop when it is flipped to see the bottom of the laptop.
    • The antennae should snap off upwards easily with a pry tool so the antennae and Wi-Fi card no longer connect.
  3. Acer Spin 7 SP714-51 Wi-Fi Card Replacement: passo 3, immagine 1 di 2 Acer Spin 7 SP714-51 Wi-Fi Card Replacement: passo 3, immagine 2 di 2
    • Use a Phillips #0 screwdriver to remove the 6 mm retaining screw from the Wi-Fi card, and carefully pull the card free to remove it from the laptop.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 225
