Salta al contenuto principale
Acer Spin 5 SP513-51-57TP Cooling Fan Replacement
Cosa ti serve
  1. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement, Battery: passo 1, immagine 1 di 1
    • Flip your laptop over so that the model sticker is facing upward towards the ceiling.
    • Make sure your computer is turned off before starting to avoid getting shocked.
  2. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: passo 2, immagine 1 di 2 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #1 screwdriver to remove the thirteen 6.5mm screws that secure the back cover.
  3. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: passo 3, immagine 1 di 3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: passo 3, immagine 2 di 3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: passo 3, immagine 3 di 3
    • Use a plastic opening tool to gently separate the back cover from the laptop. A snapping sound will be heard as a signal that the clips are being disengaged.
    • Do not use any metal tools to pry open the device.
    • It is recommended that you start from one corner and run the tool along the edges of your laptop from corner to corner for a safe removal.
  4. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: passo 4, immagine 1 di 3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: passo 4, immagine 2 di 3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: passo 4, immagine 3 di 3
    • Use a Phillips #1 screwdriver to remove two 4 mm screws that secure the battery.
  5. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: passo 5, immagine 1 di 3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: passo 5, immagine 2 di 3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: passo 5, immagine 3 di 3
    • Use your hand to carefully pull out the wiring harness from its port that is located between the battery and the motherboard.
    • Remove the battery from the case.
  6. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement, Cooling Fan: passo 6, immagine 1 di 3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement, Cooling Fan: passo 6, immagine 2 di 3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement, Cooling Fan: passo 6, immagine 3 di 3
    • Use Phillips #1 screwdriver to remove the two 4mm screws that are securing the fan.
  7. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: passo 7, immagine 1 di 2 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: passo 7, immagine 2 di 2
    • Using Phillips #1 screwdriver remove three 5 mm screws to remove the heatsink.
    • When removing the cooling fan, the heatsink component will stay connected.
  8. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: passo 8, immagine 1 di 3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: passo 8, immagine 2 di 3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: passo 8, immagine 3 di 3
    • Using your hand, pull out wiring harness to disconnect the fan from the motherboard.
    • Lift the fan out of the case to remove it.
Conclusione
Hufflepuff Membro di Hufflepuff
Local Repair Groups
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,311
