Salta al contenuto principale
Acer Spin 5 N17W2 Screen Assembly Replacement
Cosa ti serve
  1. Acer Spin 5 N17W2 Screen Assembly Replacement, Screen Assembly: passo 1, immagine 1 di 2 Acer Spin 5 N17W2 Screen Assembly Replacement, Screen Assembly: passo 1, immagine 2 di 2
    • Use the Phillips #1 screwdriver to remove the six 6mm screws.
    • Use Phillips #1 screwdriver to remove six 5mm screws.
  2. Acer Spin 5 N17W2 Screen Assembly Replacement: passo 2, immagine 1 di 1
    • Use an opening tool to pry the back cover open.
  3. Acer Spin 5 N17W2 Screen Assembly Replacement: passo 3, immagine 1 di 1
    • Use the Phillips #1 screwdriver to remove the three 5mm screws.
    • Use the Phillips #1 screwdriver to remove the three 5mm screws on another side of hinge.
  4. Acer Spin 5 N17W2 Screen Assembly Replacement: passo 4, immagine 1 di 1
    • Disconnect chips from the two end side of hinge.
  5. Acer Spin 5 N17W2 Screen Assembly Replacement: passo 5, immagine 1 di 1
    • Use the plastic opening tool to pry the hinge up.
  6. Acer Spin 5 N17W2 Screen Assembly Replacement: passo 6, immagine 1 di 1
    • Remove the wireless LAN chip from the motherboard.
  7. Acer Spin 5 N17W2 Screen Assembly Replacement: passo 7, immagine 1 di 1
    • Detach the sensors on each side of the hinge from the motherboard.
  8. Acer Spin 5 N17W2 Screen Assembly Replacement: passo 8, immagine 1 di 1
    • Detach the screen assembly from the device.
Conclusione
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 21
Tutti i Tempi: 2,544
