Salta al contenuto principale
Acer Spin 5 N17W2 Motherboard Replacement
Cosa ti serve
  1. Acer Spin 5 N17W2 Motherboard Replacement, Cooling Fan: passo 1, immagine 1 di 2 Acer Spin 5 N17W2 Motherboard Replacement, Cooling Fan: passo 1, immagine 2 di 2
    • Use the Phillips #1 screwdriver to remove six 6 mm screws.
    • Use the same screwdriver to remove six 5mm screws.
  2. Acer Spin 5 N17W2 Motherboard Replacement: passo 2, immagine 1 di 1
    • Use an opening tool to pry the back cover open.
  3. Acer Spin 5 N17W2 Motherboard Replacement: passo 3, immagine 1 di 1
    • Remove two 5 mm screws by using the Phillips #1 screwdriver.
  4. Acer Spin 5 N17W2 Motherboard Replacement: passo 4, immagine 1 di 2 Acer Spin 5 N17W2 Motherboard Replacement: passo 4, immagine 2 di 2
    • Use two opening tools to disconnect the cooling fan from the motherboard.
    • Remove the fan from the device.
  5. Acer Spin 5 N17W2 Motherboard Replacement, Motherboard: passo 5, immagine 1 di 1
    • Remove four 5 mm screws using the Phillips #1 screwdriver.
  6. Acer Spin 5 N17W2 Motherboard Replacement: passo 6, immagine 1 di 1
    • Take off the black heat sink (be careful of the grey thermal grease).
  7. Acer Spin 5 N17W2 Motherboard Replacement: passo 7, immagine 1 di 3 Acer Spin 5 N17W2 Motherboard Replacement: passo 7, immagine 2 di 3 Acer Spin 5 N17W2 Motherboard Replacement: passo 7, immagine 3 di 3
    • Remove all peripherals connecting to the motherboard.
    • Remove the second chip.
    • Remove the wireless LAN chip.
  8. Acer Spin 5 N17W2 Motherboard Replacement: passo 8, immagine 1 di 1
    • Disconnect the three connection wires.
  9. Acer Spin 5 N17W2 Motherboard Replacement: passo 9, immagine 1 di 2 Acer Spin 5 N17W2 Motherboard Replacement: passo 9, immagine 2 di 2
    • Take off the connecting port with black tape.
    • Take off the last port with purple tape.
  10. Acer Spin 5 N17W2 Motherboard Replacement: passo 10, immagine 1 di 1
    • Remove the motherboard from the device.
Conclusione
2 Commenti
I need the motherboard where I can buy it..
john fredy mendoza torres - Replica
I need the motherboard where I can buy it please...
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,451
