Salta al contenuto principale
Acer Spin 5 N17W2 Cooling Fan Replacement
Cosa ti serve
  1. Acer Spin 5 N17W2 Cooling Fan Replacement, Cooling Fan: passo 1, immagine 1 di 2 Acer Spin 5 N17W2 Cooling Fan Replacement, Cooling Fan: passo 1, immagine 2 di 2
    • Use the Phillips #1 screwdriver to remove six 6 mm screws.
    • Use the same screwdriver to remove six 5mm screws.
  2. Acer Spin 5 N17W2 Cooling Fan Replacement: passo 2, immagine 1 di 1
    • Use an opening tool to pry the back cover open.
  3. Acer Spin 5 N17W2 Cooling Fan Replacement: passo 3, immagine 1 di 1
    • Remove two 5 mm screws by using the Phillips #1 screwdriver.
  4. Acer Spin 5 N17W2 Cooling Fan Replacement: passo 4, immagine 1 di 2 Acer Spin 5 N17W2 Cooling Fan Replacement: passo 4, immagine 2 di 2
    • Use two opening tools to disconnect the cooling fan from the motherboard.
    • Remove the fan from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 834
