Salta al contenuto principale
Acer Spin 3 SP315-51-79NT Speakers Replacement
Cosa ti serve
  1. Acer Spin 3 SP315-51-79NT Speakers Replacement, Back Panel: passo 1, immagine 1 di 2 Acer Spin 3 SP315-51-79NT Speakers Replacement, Back Panel: passo 1, immagine 2 di 2
    • Using the Phillips #1 screwdriver, remove twelve (12) screws from the back panel.
  2. Acer Spin 3 SP315-51-79NT Speakers Replacement: passo 2, immagine 1 di 2 Acer Spin 3 SP315-51-79NT Speakers Replacement: passo 2, immagine 2 di 2
    • Gently pry the back plate off with your fingers.
  3. Acer Spin 3 SP315-51-79NT Speakers Replacement, Fan: passo 3, immagine 1 di 2 Acer Spin 3 SP315-51-79NT Speakers Replacement, Fan: passo 3, immagine 2 di 2
    • Using the Phillips #1 screwdriver, remove two screws securing the fan to the motherboard.
  4. Acer Spin 3 SP315-51-79NT Speakers Replacement: passo 4, immagine 1 di 2 Acer Spin 3 SP315-51-79NT Speakers Replacement: passo 4, immagine 2 di 2
    • Using the same Phillips #1 screwdriver, unscrew four screws from the heatsink.
  5. Acer Spin 3 SP315-51-79NT Speakers Replacement: passo 5, immagine 1 di 2 Acer Spin 3 SP315-51-79NT Speakers Replacement: passo 5, immagine 2 di 2
    • Remove the tape attached to the heat sink and the fan.
  6. Acer Spin 3 SP315-51-79NT Speakers Replacement: passo 6, immagine 1 di 2 Acer Spin 3 SP315-51-79NT Speakers Replacement: passo 6, immagine 2 di 2
    • Unplug the fan from the motherboard.
  7. Acer Spin 3 SP315-51-79NT Speakers Replacement: passo 7, immagine 1 di 1
    • Gently remove the fan from the device.
  8. Acer Spin 3 SP315-51-79NT Speakers Replacement, Speakers: passo 8, immagine 1 di 2 Acer Spin 3 SP315-51-79NT Speakers Replacement, Speakers: passo 8, immagine 2 di 2
    • Remove two screws (one on each speaker) securing the speakers to the motherboard with the Phillips #1 screwdriver.
  9. Acer Spin 3 SP315-51-79NT Speakers Replacement: passo 9, immagine 1 di 2 Acer Spin 3 SP315-51-79NT Speakers Replacement: passo 9, immagine 2 di 2
    • Unplug the speaker cable from the motherboard.
  10. Acer Spin 3 SP315-51-79NT Speakers Replacement: passo 10, immagine 1 di 1
    • Carefully unravel the speaker cables and remove the speakers from the device.
Conclusione
Altre 3 persone hanno completato questa guida.
Andrew Veiga
Membro da: 10/25/21
240 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 9
Tutti i Tempi: 90
