Salta al contenuto principale
Acer Spin 3 SP315-51-757C Screen Replacement
Cosa ti serve
  1. Acer Spin 3 SP315-51-757C Screen Replacement, Back Panel: passo 1, immagine 1 di 2 Acer Spin 3 SP315-51-757C Screen Replacement, Back Panel: passo 1, immagine 2 di 2
    • Remove eleven Phillips #0 screws from the back panel.
  2. Acer Spin 3 SP315-51-757C Screen Replacement: passo 2, immagine 1 di 3 Acer Spin 3 SP315-51-757C Screen Replacement: passo 2, immagine 2 di 3 Acer Spin 3 SP315-51-757C Screen Replacement: passo 2, immagine 3 di 3
    • Using an opening tool, pry open the back panel, starting at the silver screen hinges.
    • You may need to apply more force than usual. If you don't find any success at the hinges, you can try to start at another area that looks easier to open.
    • You can also use some plastic opening picks to help hold parts of the panel open while you work on other sides.
  3. Acer Spin 3 SP315-51-757C Screen Replacement: passo 3, immagine 1 di 1
    • Lift the back panel off of the laptop.
  4. Acer Spin 3 SP315-51-757C Screen Replacement, Battery: passo 4, immagine 1 di 2 Acer Spin 3 SP315-51-757C Screen Replacement, Battery: passo 4, immagine 2 di 2
    • Remove the two Phillips #0 screws holding the battery inside the laptop case.
  5. Acer Spin 3 SP315-51-757C Screen Replacement: passo 5, immagine 1 di 3 Acer Spin 3 SP315-51-757C Screen Replacement: passo 5, immagine 2 di 3 Acer Spin 3 SP315-51-757C Screen Replacement: passo 5, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using either your hands or a pair of tweezers, carefully pull the battery's cable out of its motherboard port.
  6. Acer Spin 3 SP315-51-757C Screen Replacement: passo 6, immagine 1 di 1
    • Using your hands, lift up on the battery from its slot, and carefully slide it away from you before fully lifting it out of the case.
  7. Acer Spin 3 SP315-51-757C Screen Replacement, Charger Port: passo 7, immagine 1 di 1
    Compra
    • The charger port's inner cable may be covered by a manufacturer sticker, which can be easily removed.
    • Using your nails or tweezers, unplug the charger port cable from the motherboard.
  8. Acer Spin 3 SP315-51-757C Screen Replacement: passo 8, immagine 1 di 1
    • Gently lift the charger port out of its slot in the laptop casing.
  9. Acer Spin 3 SP315-51-757C Screen Replacement, Motherboard: passo 9, immagine 1 di 2 Acer Spin 3 SP315-51-757C Screen Replacement, Motherboard: passo 9, immagine 2 di 2
    • Lift the three black tabs to release the cable connectors.
    • After the tabs are lifted, the white cables with blue ends can be pulled out of their slots.
  10. Acer Spin 3 SP315-51-757C Screen Replacement: passo 10, immagine 1 di 3 Acer Spin 3 SP315-51-757C Screen Replacement: passo 10, immagine 2 di 3 Acer Spin 3 SP315-51-757C Screen Replacement: passo 10, immagine 3 di 3
    • Remove the cables near the fan by pulling them carefully out of their slots.
  11. Acer Spin 3 SP315-51-757C Screen Replacement: passo 11, immagine 1 di 3 Acer Spin 3 SP315-51-757C Screen Replacement: passo 11, immagine 2 di 3 Acer Spin 3 SP315-51-757C Screen Replacement: passo 11, immagine 3 di 3
    • Remove the single Phillips #0 screw.
    • Unplug the speaker cable.
    • Unplug the secondary speaker cable.
  12. Acer Spin 3 SP315-51-757C Screen Replacement: passo 12, immagine 1 di 3 Acer Spin 3 SP315-51-757C Screen Replacement: passo 12, immagine 2 di 3 Acer Spin 3 SP315-51-757C Screen Replacement: passo 12, immagine 3 di 3
    • Remove the three Phillips #0 screws attached to the motherboard.
  13. Acer Spin 3 SP315-51-757C Screen Replacement: passo 13, immagine 1 di 2 Acer Spin 3 SP315-51-757C Screen Replacement: passo 13, immagine 2 di 2
    • Use a Phillips #0 screwdriver to remove four screws from the heat sink.
    • Carefully slide the motherboard from under the heat sink (it is easiest to slide the motherboard to the right).
  14. Acer Spin 3 SP315-51-757C Screen Replacement, Screen: passo 14, immagine 1 di 1
    • Remove the screws from the "L" and "R" plastic pieces using a Phillips #0 screwdriver.
  15. Acer Spin 3 SP315-51-757C Screen Replacement: passo 15, immagine 1 di 1
    • Remove four screws from the metal hinges in the corners using a Phillips #0 screwdriver.
  16. Acer Spin 3 SP315-51-757C Screen Replacement: passo 16, immagine 1 di 2 Acer Spin 3 SP315-51-757C Screen Replacement: passo 16, immagine 2 di 2
    • Using an opening tool, separate the bezel from the rest of the device.
  17. Acer Spin 3 SP315-51-757C Screen Replacement: passo 17, immagine 1 di 1
    • Remove the Phillips #0 screws attaching the screen to the display assembly.
  18. Acer Spin 3 SP315-51-757C Screen Replacement: passo 18, immagine 1 di 1
    • Using your hands, remove the screen.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 18
Tutti i Tempi: 37
