Salta al contenuto principale
Acer Spin 3 SP315-51-757C Heat Sink and Fan Replacement
Cosa ti serve
  1. Acer Spin 3 SP315-51-757C Heat Sink and Fan Replacement, Back Panel: passo 1, immagine 1 di 2 Acer Spin 3 SP315-51-757C Heat Sink and Fan Replacement, Back Panel: passo 1, immagine 2 di 2
    • Remove eleven Phillips #0 screws from the back panel.
  2. Acer Spin 3 SP315-51-757C Heat Sink and Fan Replacement: passo 2, immagine 1 di 3 Acer Spin 3 SP315-51-757C Heat Sink and Fan Replacement: passo 2, immagine 2 di 3 Acer Spin 3 SP315-51-757C Heat Sink and Fan Replacement: passo 2, immagine 3 di 3
    • Using an opening tool, pry open the back panel, starting at the silver screen hinges.
    • You may need to apply more force than usual. If you don't find any success at the hinges, you can try to start at another area that looks easier to open.
    • You can also use some plastic opening picks to help hold parts of the panel open while you work on other sides.
  3. Acer Spin 3 SP315-51-757C Heat Sink and Fan Replacement: passo 3, immagine 1 di 1
    • Lift the back panel off of the laptop.
  4. Acer Spin 3 SP315-51-757C Heat Sink and Fan Replacement, Battery: passo 4, immagine 1 di 2 Acer Spin 3 SP315-51-757C Heat Sink and Fan Replacement, Battery: passo 4, immagine 2 di 2
    • Remove the two Phillips #0 screws holding the battery inside the laptop case.
  5. Acer Spin 3 SP315-51-757C Heat Sink and Fan Replacement: passo 5, immagine 1 di 3 Acer Spin 3 SP315-51-757C Heat Sink and Fan Replacement: passo 5, immagine 2 di 3 Acer Spin 3 SP315-51-757C Heat Sink and Fan Replacement: passo 5, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using either your hands or a pair of tweezers, carefully pull the battery's cable out of its motherboard port.
  6. Acer Spin 3 SP315-51-757C Heat Sink and Fan Replacement: passo 6, immagine 1 di 1
    • Using your hands, lift up on the battery from its slot, and carefully slide it away from you before fully lifting it out of the case.
  7. Acer Spin 3 SP315-51-757C Heat Sink and Fan Replacement, Heat Sink and Fan: passo 7, immagine 1 di 1
    • Using a Phillips #0 screwdriver, remove the three screws that hold the fan on top of the motherboard.
  8. Acer Spin 3 SP315-51-757C Heat Sink and Fan Replacement: passo 8, immagine 1 di 1
    • Using a Phillips #0 screwdriver, remove the four screws that connect the heat sink to the motherboard.
  9. Acer Spin 3 SP315-51-757C Heat Sink and Fan Replacement: passo 9, immagine 1 di 2 Acer Spin 3 SP315-51-757C Heat Sink and Fan Replacement: passo 9, immagine 2 di 2
    • Remove both the fan and the heat sink with your hands.
Conclusione
JayLen T
Membro da: 02/08/24
97 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 12
Tutti i Tempi: 41
