Introduzione
If you notice that your Acer Spin 3 SP315-51-757C charger port has been damaged or something has gotten stuck inside of it, it is very easy to replace. Other than for the back panel, there are no other screws holding the charger port in place. You will simply need to unplug the port from the motherboard to remove and replace it.
Cosa ti serve
Using your nails or tweezers, unplug the charger port cable from the motherboard.
Quasi finito!
Conclusione
