Salta al contenuto principale
Acer Spin 3 SP315-51-757C Back Panel Replacement
Cosa ti serve
  1. Acer Spin 3 SP315-51-757C Back Panel Replacement, Back Panel: passo 1, immagine 1 di 2 Acer Spin 3 SP315-51-757C Back Panel Replacement, Back Panel: passo 1, immagine 2 di 2
    • Remove eleven Phillips #0 screws from the back panel.
  2. Acer Spin 3 SP315-51-757C Back Panel Replacement: passo 2, immagine 1 di 3 Acer Spin 3 SP315-51-757C Back Panel Replacement: passo 2, immagine 2 di 3 Acer Spin 3 SP315-51-757C Back Panel Replacement: passo 2, immagine 3 di 3
    • Using an opening tool, pry open the back panel, starting at the silver screen hinges.
    • You may need to apply more force than usual. If you don't find any success at the hinges, you can try to start at another area that looks easier to open.
    • You can also use some plastic opening picks to help hold parts of the panel open while you work on other sides.
  3. Acer Spin 3 SP315-51-757C Back Panel Replacement: passo 3, immagine 1 di 1
    • Lift the back panel off of the laptop.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 10
Tutti i Tempi: 2,002
