Salta al contenuto principale
Acer S200HL LCD Monitor Motherboard Replacement
Cosa ti serve
  1. Acer S200HL LCD Monitor Motherboard Replacement, Removing the Stand: passo 1, immagine 1 di 2 Acer S200HL LCD Monitor Motherboard Replacement, Removing the Stand: passo 1, immagine 2 di 2
    • Place the monitor screen face down.
    • Firmly hold the base of the stand with one hand and the bottom of the monitor with the other hand.
    • Pull the stand away from the monitor.
  2. Acer S200HL LCD Monitor Motherboard Replacement, Removing the Back Panel: passo 2, immagine 1 di 3 Acer S200HL LCD Monitor Motherboard Replacement, Removing the Back Panel: passo 2, immagine 2 di 3 Acer S200HL LCD Monitor Motherboard Replacement, Removing the Back Panel: passo 2, immagine 3 di 3
    • Use the plastic opening tool to pry the back panel from the front panel.
    • Start at one point of the crease and pry along the edge of the entire monitor for the best results.
  3. Acer S200HL LCD Monitor Motherboard Replacement: passo 3, immagine 1 di 1
    • Gently lift back panel away from the monitor.
  4. Acer S200HL LCD Monitor Motherboard Replacement, Removing Interior Motherboard Casing: passo 4, immagine 1 di 2 Acer S200HL LCD Monitor Motherboard Replacement, Removing Interior Motherboard Casing: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Magnetic Project Mat
    $19.95
    Compra
    • Be sure to keep track of where you place your screws. A magnetic mat is great for keeping your screws in one spot.
    • Unscrew the four 7.5 mm Phillips #2 screws connecting the motherboard to the metal casing.
  5. Acer S200HL LCD Monitor Motherboard Replacement: passo 5, immagine 1 di 2 Acer S200HL LCD Monitor Motherboard Replacement: passo 5, immagine 2 di 2
    • Remove the four 10 mm hex screws.
  6. Acer S200HL LCD Monitor Motherboard Replacement: passo 6, immagine 1 di 1
    • Gently lift the motherboard casing from the monitor.
  7. Acer S200HL LCD Monitor Motherboard Replacement, Removing the Connections to the Motherboard: passo 7, immagine 1 di 1
    • The following steps circled in yellow are the locations for detaching the three connectors shown in the picture.
  8. Acer S200HL LCD Monitor Motherboard Replacement, Removing the No Fuss Ribbon Cable Connector: passo 8, immagine 1 di 1
    • Lift the black seal to release the small ribbon connector (the No Fuss Ribbon Cable connector) from the motherboard.
    • The connector will be released from the motherboard immediately.
  9. Acer S200HL LCD Monitor Motherboard Replacement, Removing the ZIF Connectors: passo 9, immagine 1 di 1
    • Lift the black seal to release the large ribbon connector (the ZIF connector).
  10. Acer S200HL LCD Monitor Motherboard Replacement, Removing the Bundled Cable Connector: passo 10, immagine 1 di 1
    • Pull the bundled cable connector gently away from motherboard.
  11. Acer S200HL LCD Monitor Motherboard Replacement, Removing the Motherboard: passo 11, immagine 1 di 1
    • Gently lift the motherboard to remove it from the monitor.
Conclusione
Altre 7 persone hanno completato questa guida.
Jeffrey Kong
Membro da: 09/22/14
809 Reputazione
5 Guide realizzate
Cal Poly, Team 12-3, Forte Fall 2014 Membro di Cal Poly, Team 12-3, Forte Fall 2014
CPSU-FORTE-F14S12G3
5 Membri
10 Guide realizzate
2 Commenti
como saber si es la board o las lamparas q trae la pantalla?
y cual es la forma de reparar las lamparas
Doc acvdo - Replica
What is the specific name of that dc-in power jack?I’ m trying to replace that thing with a new one,the current one is already faulty.Can u recommend me where to find that part?Thanks!
Oreo - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 23
Ultimi 30 Giorni: 74
Tutti i Tempi: 7,086
