Salta al contenuto principale
Acer S200HL LCD Monitor Bundled Cable Connector Replacement
Cosa ti serve
  1. Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing the Stand: passo 1, immagine 1 di 2 Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing the Stand: passo 1, immagine 2 di 2
    • Place the monitor screen face down.
    • Firmly hold the base of the stand with one hand and the bottom of the monitor with the other hand.
    • Pull the stand away from the monitor.
  2. Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing the Back Panel: passo 2, immagine 1 di 3 Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing the Back Panel: passo 2, immagine 2 di 3 Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing the Back Panel: passo 2, immagine 3 di 3
    • Use the plastic opening tool to pry the back panel from the front panel.
    • Start at one point of the crease and pry along the entire monitor for the best results.
  3. Acer S200HL LCD Monitor Bundled Cable Connector Replacement: passo 3, immagine 1 di 1
    • Gently lift the back panel away from the monitor.
  4. Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing Interior Motherboard Casing: passo 4, immagine 1 di 2 Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing Interior Motherboard Casing: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Magnetic Project Mat
    $19.95
    Compra
    • Be sure to keep track of where you place your screws. A magnetic mat is great for keeping your screws in one spot.
    • Unscrew the four 7.5 mm Phillips #2 screws connecting the motherboard to the metal casing.
  5. Acer S200HL LCD Monitor Bundled Cable Connector Replacement: passo 5, immagine 1 di 2 Acer S200HL LCD Monitor Bundled Cable Connector Replacement: passo 5, immagine 2 di 2
    • Remove the four 10 mm hex screws.
  6. Acer S200HL LCD Monitor Bundled Cable Connector Replacement: passo 6, immagine 1 di 1
    • Gently lift the motherboard casing from the monitor.
  7. Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing the Bundled Cable Connections: passo 7, immagine 1 di 2 Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing the Bundled Cable Connections: passo 7, immagine 2 di 2
    • Pull the bundled cable connector gently away from motherboard.
  8. Acer S200HL LCD Monitor Bundled Cable Connector Replacement: passo 8, immagine 1 di 1
    • Grasp the other side of the bundled cable connector and gently pull the connector away from the screen.
Conclusione
Altre 2 persone hanno completato questa guida.
Jeffrey Kong
Membro da: 09/22/14
809 Reputazione
5 Guide realizzate
Cal Poly, Team 12-3, Forte Fall 2014 Membro di Cal Poly, Team 12-3, Forte Fall 2014
CPSU-FORTE-F14S12G3
5 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 22
Tutti i Tempi: 2,772
