Salta al contenuto principale
Acer Predator Helios PH315-51 RAM Replacement
Cosa ti serve
  1. Acer Predator Helios PH315-51 RAM Replacement, RAM: passo 1, immagine 1 di 1
    • Flip the laptop over.
    • There are two panels on the back. The smallest is the RAM panel.
  2. Acer Predator Helios PH315-51 RAM Replacement: passo 2, immagine 1 di 1
    • Remove the single screw holding the panel using a Phillips #1 screwdriver.
    • Use your fingernail to remove the panel.
  3. Acer Predator Helios PH315-51 RAM Replacement: passo 3, immagine 1 di 1
    • Push the clip down and move it left.
    • Push the clip down and move it right.
  4. Acer Predator Helios PH315-51 RAM Replacement: passo 4, immagine 1 di 2 Acer Predator Helios PH315-51 RAM Replacement: passo 4, immagine 2 di 2
    • The RAM should pop up when clips are moved.
    • Remove the RAM.
    • The RAM should easily be removed from the pins making sure no damage is done to the pins.
  5. Acer Predator Helios PH315-51 RAM Replacement: passo 5, immagine 1 di 1
    • Before inserting the new RAM, make sure there are more pins on the left side of the new RAM before the space in between so that the RAM goes in the slot correctly.
    • When the RAM is inserted, push it down and the hinges will automatically hold the RAM in its place.
    • Make sure to not apply pressure to any part. Everything should be done with care and ease.
  6. Acer Predator Helios PH315-51 RAM Replacement: passo 6, immagine 1 di 1
    • Close the panel by using the Phillips #1 screwdriver.
Conclusione
To make sure everything works correctly, power ON the laptop. It will take longer than usual to boot up because the RAM is initializing itself. When the laptop turns ON, go to about Your PC section and there you will see installed RAM and now your laptop is ready to use.
Aakarshak Jain
Membro da: 07/26/23
233 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 19
Tutti i Tempi: 232
