Salta al contenuto principale
Acer One 10 S1003-19GY Keyboard Ribbon/Dock Repair
Cosa ti serve
  1. Acer One 10 S1003-19GY Keyboard Ribbon/Dock Repair, Back Panel: passo 1, immagine 1 di 2 Acer One 10 S1003-19GY Keyboard Ribbon/Dock Repair, Back Panel: passo 1, immagine 2 di 2
    • Power off the device and make sure it is disconnected from any external devices.
    • Use a plastic opening tool to create a gap between the front and back casing of the device.
    • Slowly maneuver the plastic tool around the entire perimeter of the tablet to separate the front and back.
  2. Acer One 10 S1003-19GY Keyboard Ribbon/Dock Repair: passo 2, immagine 1 di 1
    • Set the device screen side down and remove the back casing.
  3. Acer One 10 S1003-19GY Keyboard Ribbon/Dock Repair, Keyboard Ribbon/Dock: passo 3, immagine 1 di 3 Acer One 10 S1003-19GY Keyboard Ribbon/Dock Repair, Keyboard Ribbon/Dock: passo 3, immagine 2 di 3 Acer One 10 S1003-19GY Keyboard Ribbon/Dock Repair, Keyboard Ribbon/Dock: passo 3, immagine 3 di 3
    • Flip the latch and carefully pull the ribbon free.
  4. Acer One 10 S1003-19GY Keyboard Ribbon/Dock Repair: passo 4, immagine 1 di 2 Acer One 10 S1003-19GY Keyboard Ribbon/Dock Repair: passo 4, immagine 2 di 2
    • Remove the two screws holding the dock in place using a Phillips #0 screwdriver.
    • Pull the dock out and slide it out of the device.
Conclusione
Un commento
dove acquistare questo connettore :Acer ONE 10 (S1003 D16H1) Docking Port Connector Cable, grazie . francescomar25@gmail.com
Francesco - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,287
