Salta al contenuto principale
Acer One 10 S1002 145-A Motherboard Replacement
Cosa ti serve
  1. Acer One 10 S1002 145-A Motherboard Replacement, Motherboard: passo 1, immagine 1 di 1
    • Make sure that the tablet is turned off and disconnected from any power source.
    • Disconnect the tablet from the keyboard attachment.
    • If you have a Micro SD card in the tablet, remove it now.
    • Remove the two 3.5 mm Phillips #0 screws on either side the keyboard connection.
  2. Acer One 10 S1002 145-A Motherboard Replacement: passo 2, immagine 1 di 2 Acer One 10 S1002 145-A Motherboard Replacement: passo 2, immagine 2 di 2
    • Starting from a corner of the tablet, use the plastic opening tool to create a gap between the screen and the back covering.
    • Slowly maneuver the plastic opening tool along the perimeter of the tablet to pry the screen and back covering apart.
    • Separate the back covering from the screen.
  3. Acer One 10 S1002 145-A Motherboard Replacement: passo 3, immagine 1 di 3 Acer One 10 S1002 145-A Motherboard Replacement: passo 3, immagine 2 di 3 Acer One 10 S1002 145-A Motherboard Replacement: passo 3, immagine 3 di 3
    • Peel off all of the Polyimide tape (yellow tape).
    • Remove the metallic tape covering the keyboard connection.
  4. Acer One 10 S1002 145-A Motherboard Replacement: passo 4, immagine 1 di 2 Acer One 10 S1002 145-A Motherboard Replacement: passo 4, immagine 2 di 2
    • Unscrew the two 3.5mm Phillips #0 screws and open the ZIF latch.
    • Gently remove the silver part covering the battery and set it aside.
  5. Acer One 10 S1002 145-A Motherboard Replacement: passo 5, immagine 1 di 3 Acer One 10 S1002 145-A Motherboard Replacement: passo 5, immagine 2 di 3 Acer One 10 S1002 145-A Motherboard Replacement: passo 5, immagine 3 di 3
  6. Acer One 10 S1002 145-A Motherboard Replacement: passo 6, immagine 1 di 2 Acer One 10 S1002 145-A Motherboard Replacement: passo 6, immagine 2 di 2
    • Remove the four 4mm screws at the corners of the motherboard with the Phillips#0 bit screw.
    • The screw beneath the metallic tape also needs to be removed.
  7. Acer One 10 S1002 145-A Motherboard Replacement: passo 7, immagine 1 di 3 Acer One 10 S1002 145-A Motherboard Replacement: passo 7, immagine 2 di 3 Acer One 10 S1002 145-A Motherboard Replacement: passo 7, immagine 3 di 3
    • Disconnect the three cables on the motherboard closest to the battery.
    • These cables require some extra prying power to be removed.
  8. Acer One 10 S1002 145-A Motherboard Replacement: passo 8, immagine 1 di 1
    • Slide out the motherboard and put it aside.
Conclusione
Altre 12 persone hanno completato questa guida.
USF Tampa, Team 1-3, Sullivan Fall 2016 Membro di USF Tampa, Team 1-3, Sullivan Fall 2016
USFT-SULLIVAN-F16S1G3
4 Membri
5 Guide realizzate
11 Commenti
WOW. Thank you so much for this guide. My keyboard wasn't connecting and last time I had to send it to Acer ...and that took a month. This time it is out of warranty and it wouldn't connect again!!!.... After opening it following this guide, it was immediately visible that the cable was out.
Thank you SO much!
Alen Mijic - Replica
put it aside and then?
Double Bone - Replica
Hey,
Whenever you see a 'put aside' anywhere in a guide there's an implied 'then continue' afterwards.
Hope that helps!
Allen Tools -
Great help. Was able to restore connection for my grandson’s computer using your clear concise directions. THANK YOU!!!
Linda Byars - Replica
how can i fix my acer one s1002 keyboard dock it is not working if i connect it to the tablet i
Wencel Angelo Maturan - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 42
Tutti i Tempi: 17,908
