Salta al contenuto principale
Acer One 10 S1002 145-A Key Replacement
Cosa ti serve
  1. Acer One 10 S1002 145-A Key Replacement, Key: passo 1, immagine 1 di 1
    • Make sure device is powered off and disconnected from any power supply.
    • Disconnect the tablet screen from the magnetic hinge where the keyboard is attached.
    • Pry off the damaged key by using the nylon spudger to gently push the key upwards.
  2. Acer One 10 S1002 145-A Key Replacement: passo 2, immagine 1 di 1
    • If the white plastic horizontal spring becomes misaligned, re-align and pop the two hinges back into place with the tweezers or your fingers.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team 1-3, Sullivan Fall 2016 Membro di USF Tampa, Team 1-3, Sullivan Fall 2016
USFT-SULLIVAN-F16S1G3
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 22
Tutti i Tempi: 7,943
