Salta al contenuto principale
Acer Nitro 5 AN517-51-56YW Battery Replacement
Cosa ti serve
  1. Acer Nitro 5 AN517-51-56YW Battery Replacement, Bottom Cover: passo 1, immagine 1 di 3 Acer Nitro 5 AN517-51-56YW Battery Replacement, Bottom Cover: passo 1, immagine 2 di 3 Acer Nitro 5 AN517-51-56YW Battery Replacement, Bottom Cover: passo 1, immagine 3 di 3
    • Place the laptop upside-down so that the fans are facing away from you.
    • Remove the twelve 6.7 mm screws from the bottom cover using a Phillips #1 screwdriver.
    • Pry the bottom cover away from the laptop using a spudger.
  2. Acer Nitro 5 AN517-51-56YW Battery Replacement, Battery: passo 2, immagine 1 di 2 Acer Nitro 5 AN517-51-56YW Battery Replacement, Battery: passo 2, immagine 2 di 2
    • Unplug the connection plug that attaches the battery to the motherboard.
    • Make sure to pull the connector safely so that it doesn't break.
    • Remove the two 4.7 mm screws using a Phillips #1 screwdriver.
  3. Acer Nitro 5 AN517-51-56YW Battery Replacement: passo 3, immagine 1 di 2 Acer Nitro 5 AN517-51-56YW Battery Replacement: passo 3, immagine 2 di 2
    • Remove the battery from the laptop.
    • Make sure that your laptop powers on before you begin reassembly. If it does not start, make sure the battery is firmly connected to the motherboard.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 69
Tutti i Tempi: 1,626
