Salta al contenuto principale
Acer Nitro 5 AN515-57 RAM Replacement
Cosa ti serve
  1. Acer Nitro 5 AN515-57 RAM Replacement, RAM: passo 1, immagine 1 di 2 Acer Nitro 5 AN515-57 RAM Replacement, RAM: passo 1, immagine 2 di 2
    • Shut-down your laptop and unplug the battery connection.
    • Remove any other device attached to the laptop.
  2. Acer Nitro 5 AN515-57 RAM Replacement: passo 2, immagine 1 di 1
    • Remove eleven screws from the bottom case of the laptop using a Phillips #00 screwdriver.
  3. Acer Nitro 5 AN515-57 RAM Replacement: passo 3, immagine 1 di 2 Acer Nitro 5 AN515-57 RAM Replacement: passo 3, immagine 2 di 2
    • Slide an iFixit opening tool into the front lip of the laptop and slowly move your way around the chassis.
    • Make sure not to slide the tool too deep as it can damage the board.
  4. Acer Nitro 5 AN515-57 RAM Replacement: passo 4, immagine 1 di 2 Acer Nitro 5 AN515-57 RAM Replacement: passo 4, immagine 2 di 2
    • Disconnect the battery by either using the iFixit opening tool or your fingers.
  5. Acer Nitro 5 AN515-57 RAM Replacement: passo 5, immagine 1 di 3 Acer Nitro 5 AN515-57 RAM Replacement: passo 5, immagine 2 di 3 Acer Nitro 5 AN515-57 RAM Replacement: passo 5, immagine 3 di 3
    • Use your fingers to pull the silver latches on either side of the RAM away from each other.
    • The RAM will pop up by a few centimeters.
    • Remove the RAM from the laptop.
  6. Acer Nitro 5 AN515-57 RAM Replacement: passo 6, immagine 1 di 1
    • Reconnect the battery pins
    • While reconnecting the battery, try not to touch the metal prongs.
  7. Acer Nitro 5 AN515-57 RAM Replacement: passo 7, immagine 1 di 2 Acer Nitro 5 AN515-57 RAM Replacement: passo 7, immagine 2 di 2
    • Place the back panel on to your laptop and gently press on it until it snaps in place.
    • Screw the back panel back in.
    • When turning on your laptop the first time after installing new RAM, it may take the laptop a few minutes to turn on.
Linea Traguardo
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 29
Ultimi 30 Giorni: 141
Tutti i Tempi: 4,379
