Salta al contenuto principale
Acer Nitro 5 AN515-55-55M1 Speakers Replacement
Cosa ti serve
  1. Acer Nitro 5 AN515-55-55M1 Speakers Replacement, Bottom Cover: passo 1, immagine 1 di 1
    • Make sure the device is off and unplugged from power.
    • Flip the device so the bottom is facing up.
    • Remove 11 screws from the bottom case using a Phillips #1 screwdriver.
  2. Acer Nitro 5 AN515-55-55M1 Speakers Replacement: passo 2, immagine 1 di 2 Acer Nitro 5 AN515-55-55M1 Speakers Replacement: passo 2, immagine 2 di 2
    • Lift the top left and right corners up and away from the device.
    • This may require some force and will make harsh clicking sounds. This is normal; it's the plastic tabs separating from each other.
    • Remove the panel from the laptop.
  3. Acer Nitro 5 AN515-55-55M1 Speakers Replacement, Speakers: passo 3, immagine 1 di 3 Acer Nitro 5 AN515-55-55M1 Speakers Replacement, Speakers: passo 3, immagine 2 di 3 Acer Nitro 5 AN515-55-55M1 Speakers Replacement, Speakers: passo 3, immagine 3 di 3
    • Use an iFixit opening tool to unplug both speaker connectors from the motherboard.
  4. Acer Nitro 5 AN515-55-55M1 Speakers Replacement: passo 4, immagine 1 di 2 Acer Nitro 5 AN515-55-55M1 Speakers Replacement: passo 4, immagine 2 di 2
    • Lift the speakers straight up and out of their shells.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 28
Tutti i Tempi: 510
